How far does a pressed in stud go into the boss?
Old Aug 31, 2007 | 08:10 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have to pin the pressed-in studs on my heads, but even with a 90 deg. drill adapter, I still wont be able to get them in straight. Ill have to angle them and I want to make sure the pin will actually intersect the entire stud. How far in does it go?
Old Aug 31, 2007 | 02:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: How far does a pressed in stud go into the boss?
About 5/8" or so.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
