Oil Temp, Trans Temp Gauge INSTALL?
Old Sep 3, 2007 | 10:52 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
How do i do it? The wiring of the gauges is cool. But where do i put the senders? I did a search but i had a real hard time, finding anything helpful.
Basically, do i need to go to the bulk of the oil supply? ie: at the pans? Or can i place the sender into a line? ie: same place i measure my oil pressure for oil, and in the trans cooler lines for the trans?
If someone has done this install before, and can get me some pix and/or instructions for where to place the sender that would be great!
I have a 1975 350 carbed with a 700R4 trans. Thanks.
Old Sep 4, 2007 | 12:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Temp, Trans Temp Gauge INSTALL?
Anywhere you want, really. The actual temperature isn't as important as being able to see if changes abnormally.
rocn7roc
Sep 21, 2021 02:16 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
