New Valve cover question
Old Sep 7, 2007 | 12:16 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Okay I got my new valve covers yesterday and I am going to do the install on Sunday. 305...TBI. Of the three holes in the valve cover they sold me TWO breathers in lieu and the oil cap which I know I can fill the oil this way. And I know that the third hole is for the PCV.
My question is can I really run breathers in each valve covers?
Old Sep 7, 2007 | 12:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: New Valve cover question
Not if you want to have a working PCV system.
Old Sep 7, 2007 | 02:06 PM
Axle/Gears: Posi
so what do I put in that third hole? The covers have 3 holes and 3 grommets. It does not seem big enough for a oil cap as long as the grommet is in it.
Old Sep 7, 2007 | 02:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
One side gets a PCV valve, the other side gets a breather, and an oil filler cap goes in the third hole.
Old Sep 8, 2007 | 01:18 AM
Axle/Gears: Posi
I understand that. They did not have an oil cap that fit and substituted an additional breather. I since posting have talked to the dealer and they are fitting me up with a closed grommet.
Old Sep 9, 2007 | 03:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That will work. You can also get oil-fill caps that are 'push-on' style that will fit on just like a plug or breather cap. You can use any of the holes for an oil-fill hole... just pull out the breather or PCV valve to fill, then put it back. My covers only have one hole in each and thats what I do.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
