white smoke
Old Sep 8, 2007 | 01:27 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
white smoke
i have a 1984 camaro with the l69 i just changed valve seals but still get white smoke while running but it isnt burning oil or coolant they are still full ?
Old Sep 8, 2007 | 01:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: white smoke
it must be pretty warm down in KY right now... it isnt oil if it is truely white... it is coolant the fact it is coming out the exhaust does narrow it down a bunch...
you can start the car and get yourself a small mirror/ piece of glass hold it right infront of the exhaust.. if you get moisture your have a blown headgasket... no moisture it is something else but if it is white it is probably a blown head gasket
why did you do valve seals if the smoke is white? does it have a blueish tint to it... smell like burning oil?
Old Sep 8, 2007 | 01:41 PM
Engine: L69 H.O
Re: white smoke
right before i did valve seals when you would start it you couldnt see your hand in front of your face in the garage lol after the valve seals it seemed to calm the smoke down alot now you can only see it if you are standing right behind the car
Old Sep 8, 2007 | 01:47 PM
Car: 91 RS
Engine: 350 vortec
Re: white smoke
but is the smoke white? does it smell like oil?
Old Sep 8, 2007 | 01:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: white smoke
while you had the valve covers off , did you make sure the drain holes in the front & rear corners of the cylinder head were not sludged up ? they allow the oil from the valves to drain back to the pan . if they are blocked or sludged up oil will not drain from the heads back to the pan fast enough . new seals or not oil can buildup/collect and run down the guides . sounds like that may be your problem. happened to me when i was in a hurry . ream drain holes with a screwdriver , and a blast of air should do it .
Old Sep 8, 2007 | 01:53 PM
Engine: L69 H.O
Re: white smoke
would it make it smoke if they were clogged up
Old Sep 8, 2007 | 01:59 PM
UNCLE TOM's Avatar
Re: white smoke
WHY YES , oil cannot drain back to the pan fast enough . it builds up and goes down the valve guides . then you get smoke from the oil. CHECK THEM .
Old Sep 8, 2007 | 02:45 PM
Engine: L69 H.O
Re: white smoke
thanks for the reply i will check. Also i just went out and started it it dosent smoke on startup but the warmer the engine gets the more smoke. Also the higher you rev it the more smoke comes out. It isnt a whole lot but it is still notice able and even with the engine warm i get little water droplets coming out of the exhaust tips
Old Sep 8, 2007 | 03:36 PM
UNCLE TOM's Avatar
Re: white smoke
the water droplets could be just condensation . take it out for a drive [ not in the rain ] get up to normal operating temp. , about 20-30 mins. . go back home if water is still coming out of tailpipe you may have other issues . any other recent issues/ problems ?
Old Sep 8, 2007 | 09:05 PM
Car: 91 RS
Engine: 350 vortec
Re: white smoke
Does the car sit for long periods of time? when was the last oil change it would take alot of condensation to be dripping out the tail pipes and have...lots of white smoke...
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
