Car Stalls when braking
Old Sep 13, 2007 | 10:14 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Just rebuilt 305 tpi. When cold, runs and drives just fine. When motor is warmed up, after braking the rpms drop to 500 and car sometimes stalls because of rpm drop. Any ideas?
Old Sep 15, 2007 | 12:26 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Re: Car Stalls when braking
For what it's worth mine is doing that too. Except mine does it after only a few minutes and only when the car is moving. Sitting in the garage I can pump the brakes and the idles goes up a tad. Sure hope we get an answer.
Here are some ideas.
https://www.thirdgen.org/forums/tech...-car-quit.html
Old Sep 15, 2007 | 03:04 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
First thing I would check for would be a vaccum leak. If you find nothing there than maybe check your fuel flow to see if you maybe have a clogged fuel filter.
Old Sep 15, 2007 | 08:38 AM
Car: '86 Iroc Z
I just replaced all 8 fuel injectors and put a brand new fuel filter in. The only vacuum leak I have is from my throttle body to the emissions canister (the throttle body sucks air in from the canister. When I connect the line or plug the hole, the car stalls right away. I also can not plug my mass air flow sensor in or the car stalls.)
My best guess is my car is slightly out of time???
Old Sep 15, 2007 | 11:43 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
no the car being out of time...wont cause that... i would bet you need a new MAF... if you cant plug yours in without it stalling
Old Sep 15, 2007 | 12:40 PM
Car: '86 Iroc Z
Is that the sensor in the air induction box?
Old Sep 15, 2007 | 04:10 PM
Car: 91 RS
Engine: 350 vortec
that is the sensor in the aircleaner cover before the TB
Terrell351
Jun 13, 2021 01:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
