finally fixed the miss... now...
Old Sep 18, 2007 | 07:51 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
fixed the miss... was a wire burned on the headers..... i checked it a million times ... doh... i also changed the spark plugs while i was at it..
anyways now i have a different problem... hard accel like apssing someone i have a pretty bad backfire through the carb problem.
Never happened before.... now if i accelerate is will chug and pop thru the carb, not a huge backfire but its decent.... enough to be seen thru the cowl at night.
Timing has never been changed since i got the motor running .... its at 10* adv base timing with the vacuum advance on ported vacuum... IIRC.
the floats on hte carb are set a bit high... easy enough to fix on my demon... would this be the problem...
also i noticed since i swapped the plugs my car has been running rich latley... like to the point where i smell it and it puff black a bit at idle... and a cloud when i stomp it... i tried playing with the 4corner idle bleeds but i got frustrated because i could see any changes... is it righty lean or lefty lean... whats the best way to adjust them when theres one on each corner... arggg i have to much to do at work to test and tune my car... any suggestions????
Old Sep 18, 2007 | 09:21 PM
rhamm1320's Avatar
Re: finally fixed the miss... now...
Is it possible when you changed the plugs you got the firing order wrong? Sometimes you can be absolutely positive you have it right, then check it again and a couple are crossed.
Old Sep 19, 2007 | 07:07 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
100% not possible... i did each plug one at a time and it runs fine aside from WOT.. was paying attn more today coming home from work... she's gone pig rich and i dont know why...
WOT is black like a diesel.... i didnt jet it up i dont know why it would run suddenly rich??
Old Sep 19, 2007 | 11:04 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i would doubt it is rich...more likely lean
Old Sep 20, 2007 | 06:46 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
do you not read... it is definately rich..... lean doesnt blow more black smoke than a locomotive....
anyways ... my car ran outta gas yesterday while driving.. no fuel or odo so i guess.. lol dicked around with the idle mixture screws and it now running less rich but the idle screws are only 3/4 turn out from full lean
Old Sep 20, 2007 | 08:02 PM
Car: 91 RS
Engine: 350 vortec
um yeah back fire through carb is a sign of a lean spot especially when you get in it... sounds like you need to learn how to read smartass cause if you had even bothered to do any searching in the CARB board you would have seen about a million people who have already had the exact same problem...
but maybe that is like that plug wire you checked a million times.... the 1000001 times the charm eh?
and just because it is puffing black smoke at WOT doesn't mean your primaries are also rich... could be but that type of backfire through the carb means you are having a transition problem...from the idle to main metering circuits
although 3/4 is a bit rich for a 4 corner idle it is hard to tell exactly what your engine needs... do you have both primary and secondary throttle blades adjusted correctly? what cam and squirter are you running on the primarys?
ALSO and this is important as alot of people dont realize that when you switch to a decent siezed cam... your exhaust will always smell much more rich than a new FI car trying to tune that out is almost impossible
Old Sep 24, 2007 | 12:46 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well thanks for not being helpful unlike he carb board... anyways the 4 corners were adjusted too rich leaning it out solved the WOT smoke and the backfires... and i never said or mention the jets being the problem.... have a nice day
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Reese-J
Sep 14, 2015 02:43 PM
