Weird idling
Old Sep 20, 2007 | 08:46 PM
camaro_guy85's Avatar
Car: 85 camaro z28
Engine: 5.0 v8
Weird idling
Hey guys so i have a 85 camaro 305 tpi it runs kinda rough it idles kinda low on cold start when it should be idling high to get the engine warmed up but does the complete opposite it idles faster and higher after being run for a while and often when i put it in reverse and back out and give it some gas it tries to stall out then hesitates and sometimes actually does stall out if any of u guys have any ideas wat it could be please let me know
Old Sep 22, 2007 | 09:30 PM
johnfwz28's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
Re: Weird idling
check your IAC valve. (idle air control)
Old Sep 22, 2007 | 09:45 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: Weird idling
Well, I mean, my car gets all lumpy sounding on a cold-start then goes right back up to it's regular idle point. It seems like a normal issue, since cold-starts are hard on any engine. But your problem could be the IAC.
Old Sep 23, 2007 | 03:12 AM
Car: 85 camaro z28
Engine: 5.0 v8
Re: Weird idling
ya but isnt that part of the throttle body or near it? i mean ive had it in the shop like i said and the mechanic should have overlooked that if it is part of the throttle body cuz he cleaned it and checked things over and said everything seemed fine on top of that it only tries to stall in reverse?
gta892000
Aug 11, 2019 11:16 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
