How do I rig a heated O2 sensor?
Old Sep 23, 2007 | 03:31 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
How do I replace my single wire O2 sensor with a heated 3 wire? Search seems to be down, so advice would be appreciated.
Also, what part would I ask for at the parts house?
Old Sep 23, 2007 | 03:39 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: How do I rig a heated O2 sensor?
there is an univeral 3 wire, color codes are in the package, run one wire to a hot with igniton and the other heater wire to ground, then hook up the signal wire to the ECM
Old Sep 23, 2007 | 03:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you want to go one step further, tap into the fuel pump relay so that it only has power when the fuel pump is energized.
Old Sep 23, 2007 | 04:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ya don't want the heated O2 to be heated all the time. Its only there to preheat the thing so it reacher proper temp faster [almost instantly] so the car don't hafta run in loop mode till it heats up normaly.
Ya know when your 3rd gen does that funny rev up n down on its own till warm. Wecome to loop mode as it waits for the O2 to heat up enough to send a proper signal. Why they are so close to the engine, it need heat to read right.
Would probably burn it out if left on all the time. Unless you had it moved to a "colder" spot where a regular O2 would never heat up enough.
Id still put a good fuse on that line, if it gets to hot, it should make enough resistance to pop it.
Old Sep 23, 2007 | 05:17 PM
Engine: tpi 305
So I just go into autozone and ask the kid for a universal three wire? No specific application?
Does the advantage of the three wire outweigh the hassle of it burning itself out as Gumby mentions.
I've got headers, by the way.
Old Sep 24, 2007 | 04:35 AM
Kurt04's Avatar
Bosch 13077 is the one you want, unless you wanna spend more for an OEM one from a ZR1 Corvette.
You can get a connector pigtail from www.eficonnection.com
Old Sep 24, 2007 | 08:02 AM
Here's the EASIEST one to use.
http://www.partsamerica.com/ProductD...pe=291&PTSet=A
You cut the pigtail off of your existing O2 sensor, and use that; then you add power and ground wires. Ground to the engine block, get the power from the fuel pump relay.
Old Sep 24, 2007 | 10:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Might be the same one as what sofa just mentioned, but I got a "1987 Ford F150 oxygen sensor, with the 302 engine".
And got a 3 wire one for $60.
Old Sep 25, 2007 | 10:48 AM
Engine: tpi 305
Got a universal three wire and rigged it in. Between that and unplugging my IAC, the car is idleling and running MUCH better.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
