car doesn't run right when warmed up????
Old Sep 25, 2007 | 11:53 AM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
Hello again,
I recently replaced all the plugs and wires because my car simply doesn't run right when its warmed up .....When I go to take off the car acts like it wants to die stuttering and such...play with the throttle a little bit and I can get it to take off....it runs alright at higher rpm's say 2500+.....someone suggested that it was probably a vacuum leak.....I was wondering if this was a common problem and if there was a vacuum line that usually goes bad or something.....
Thanks,
Steve
Old Sep 25, 2007 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Having a clue as to what year, engine, and induction you have would be helpful.
Old Sep 25, 2007 | 02:08 PM
Re: car doesn't run right when warmed up????
well I mean you could check my garage but
1987 Iroc-z Camaro TPI 305 all stock
Old Sep 25, 2007 | 03:41 PM
five7kid's Avatar
Originally Posted by kdxrider9262
well I mean you could check my garage ...
In fact I did. It said "64k original miles from California....no rust!", that's all. I see you've added the information to your profile now - very good.
Vacuum leak isn't a bad guess. As for which hose could go bad - all of them. Also loose fittings, loose TB or intake/runner/plenum bolts. Or, bad power brake booster.
Fuel pump would be another possibility, except running better above 2500 RPMs doesn't fit that. Actually, few things that come to mind do fit that particular piece.
Old Sep 25, 2007 | 07:18 PM
well I got absolutely nowhere today I bought a new dist cap and brought my dad over to check it out...after about an hour of troubleshooting and checking things out we were both clueless........gonna hook it up to the machine tomorrow and see what it says....its runs too bad not to have something obvious wrong.......at an idle if you floor it it just falls flat on its face.......but get it to run and it'll scoot up the road at higher rpm's
Old Sep 26, 2007 | 10:06 AM
bumpalump
Old Sep 26, 2007 | 08:50 PM
Bandit5's Avatar
Now, I am not the best engine tech here, but it sounds to me like it is running rich after you warm it up. My guess... bad O2 sensor.
Old Sep 26, 2007 | 08:55 PM
87irocruns13's Avatar
Car: 87 Iroc, recently ran 13.733 @98.54
Engine: 350 HSR
Double check your fuel pressure with a gauge, had the same problem with car running better at higher RPMs, I know that doesn't make since but check it again.
Old Sep 26, 2007 | 09:31 PM
thanks for the reply's.....I went to my old work and had them hook it up to the scanner......came back with MAF sensor reading too high, and EST spark problem....which was thrown cause we just set the timing.....so.....MAF sensor it is!
specialized
Jun 18, 2022 09:26 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
