Unhooked Connector
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Unhooked Connector
Where does this connector plug into? The wires that run into it go to the fuses in the fuse block for the injectors. It is located near the ecm.
Car: 85 Iroc-Z
Transmission: 4L80E/4L80E
No idea specifically, but unless someone has been under there disconnecting things, I'd guess it's for something your car doesn't have.
Car: 85 Iroc-Z
Re: Unhooked Connector
Well all of a sudden i lost power to my injectors so im wondering if this could be the problem since they worked one day and after i put my interior in they didnt.
I'm officially over my head. I've never had direct experience with TPI.
Car: 85 Iroc-Z
3 wires, one black, one pink, one pink with black stripe.
Hmmm.. you got me... the wires are: black = ground, pink = ignition, pink w/black stripe = ignition off of the ECM fuse (typically powers sensors and solenoids and such)
May not go to anything, might just be the factory's test connector, where they hooked up to the harness to check out that and ECM at the component mfg plant before assembling it into a car...
Check your INJ1 & INJ2 fuses, and ECM fuse.
Car: 85 Iroc-Z
Heres the link again. The fuses are good.Also after taking notice the one wire isnt black its brown.http://s214.photobucket.com/albums/c...t=DSC02786.jpg
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
That connector will plug into your dash harness. Take a close look around, the mating connector is going to be close by. On the early harnesses, they used that grey connector in addition to the C207 connector on the right of the picture. Notice that just about all if not all the cavities on the C207 connector are full, hence the need for the second connector.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
