canister
Old Sep 26, 2007 | 01:21 PM
tak0064's Avatar
Car: 1990 formula 305 tbi
Engine: 305 tbi
canister
I was looking at vacuum diagrams earlier that show the purge canister in the front corner of the engine bay of the 305 models, and i noticed that there is not currently one in my car. All of the egr stuff in my car was taken out before i bought it, and i was just wondering if this canister is a necessary piece, or will my car run fine without it?
Old Sep 26, 2007 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It provides venting of the fuel tank, a rather important function.
Old Sep 26, 2007 | 04:14 PM
tak0064's Avatar
Engine: 305 tbi
Re: canister
ok that seems pretty important... all if the lines that originally went to the canister are still in place, just not the canister. Could this be a bad thing to leave like this, or should i go find a canister for it?
Old Sep 26, 2007 | 04:56 PM
Pocket's Avatar
Car: 91 Trans Am
Re: canister
You lose a big chunk of gas mileage without it
Old Sep 26, 2007 | 05:04 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: canister
um.. ya kinda dangerous. gas is not bad but gas vapor. boooom. If you smell it then you really need it. It's kinda like having a really small gas cap off your tank. find one in the junk yard or something.
Old Sep 26, 2007 | 05:12 PM
tak0064's Avatar
Engine: 305 tbi
Re: canister
just went and picked one up, and it looks like it bolted right up, wasn't missing any hoses or anything under the hood.
Old Sep 26, 2007 | 05:46 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: canister
You made sure to hook up the wiring for the purge solenoid, correct?
Old Sep 26, 2007 | 06:04 PM
tak0064's Avatar
Engine: 305 tbi
Re: canister
it looks like all of the ports on the whole part are plugged into where they need to be. would the canister still work if i turned it upside down and put it under the panel it is bolted up stock at? i kind of want to keep my engine less cluttered and it looked 10x better without it. however, i don't know much about fuel systems and this part so i want to keep everythign working right...
Old Sep 26, 2007 | 06:12 PM
five7kid's Avatar
I've wondered about cutting a hole in that panel and mounting the canister down flush. That's the way I've seen some factory canisters mounted (my fullsize '84 van, for instance). You should have a shield between it and the tire to keep the filter a little cleaner.
I don't know that there would be a problem mounting it upside down, but I don't think that would be my first choice.
Old Sep 26, 2007 | 06:19 PM
tak0064's Avatar
Engine: 305 tbi
Re: canister
cool thanks for the input. ill go out and see if i can't find any other ways to hide it a little better. anyone else have any ideas?
Old Sep 26, 2007 | 07:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: canister
Local club member moved his canister under where it sits now (inside the fender) and extended the wires/hoses to reach
I test fitted it down there and it has barely enough room
I will be moving it there eventually and Ill post the progress
Old Sep 26, 2007 | 08:38 PM
tak0064's Avatar
Engine: 305 tbi
Re: canister
the only problem i had with trying to get mine to fit under there earlier, is that the sphere thing is directly under it. if i try i may be able to get them to fit side by side, but i didnt think about that at the time
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
reactor60
Sep 22, 2015 01:44 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
