327 or 350?
Old Oct 4, 2007 | 02:58 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
327 or 350?
im buying a what i think is a 350 engine block tommorrow evening.
that casting numbers are 3970010.
i forgot to check the casting for the date.
i was reading on a site saying that if its from 1968 its a 327 from 1969 and above are all 350s.
is that true?
and how do i tell what the engine it came from?
im wondering if it came from a car or a truck.
where do i look for that?
ill post some photos of the block tommorrow when i get it.
the bore size is 4.000
Old Oct 4, 2007 | 03:32 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
Re: 327 or 350?
Same block It's the crank stroke that changes, and pistons are different. Besides, your torque flatens out quicker than a 350. Think 383, its stroke for torque!
Also crunch the numbers to rebuild a stock 327 vs. 350. Depending on what you want any build will get pricey.
To find what it came out of, try googleing chevy engine suffix. It'll show where and what to look for.
Good luck, just remember don't buy junk.
Old Oct 4, 2007 | 07:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
'68-'69, could be either a 327 or 350. As stated, it's the crank (and pistons) that make the difference. Pretty good odds that it's a 350.
What it came out of is pretty much moot. The only difference that makes is 2- or 4-bolt main, cam, and heads. The number of main bolts is also moot. Cam and heads are better to change than run what came in/on it, anyway.
Old Oct 5, 2007 | 11:14 AM
VETTEpwrdZ28's Avatar
Car: 75 SHORTBED
Axle/Gears: stock
Re: 327 or 350?
i have a 68 327 from an impala SS, blew the doors of plenty of IROC'S i love my 327
Old Oct 5, 2007 | 12:54 PM
five7kid's Avatar
Ditto for my 305 on steroids.
The 327 was a decent engine in its day (had more than one myself), but really isn't anything particularly special.
Old Oct 5, 2007 | 01:31 PM
88_SC_305's Avatar
Car: 1988 Camaro
Engine: 305 5.0L....355 being built
Axle/Gears: 2.73 non-posi GM 7.5" 10 bolt
Re: 327 or 350?
if it is a 327, its a truck engine from 1969 and is 2 bolt mains. if it is a 350, it could be anywhere from 1969 to 1980 and could be either a 2 or 4 bolt mains. so if its a 4 bolt, you'll know its a 350. but if its a 2 bolt, on the back of the engine there should be the engine size in liters, 350 is 5.7, im not sure what 327 is.
Old Oct 5, 2007 | 02:32 PM
five7kid's Avatar
They didn't put the engine size on the casting back then. Obviously, since they used the same casting for two different engine sizes, that wouldn't be a wise thing to do.
Old Oct 5, 2007 | 03:08 PM
88_SC_305's Avatar
Car: 1988 Camaro
Re: 327 or 350?
i wasnt sure if they did or not, i just saw a 350 in the shop the other day with "GM 5.7L" cast into it. and since they used the same casting numbers for 2 engines, id figure it WOULD be a smart idea to also cast the engine size on it. unless u meant using the same casting number wasnt smart.
Old Oct 5, 2007 | 04:51 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: 327 or 350?
Also be aware the 327 came in small and large journal on the rods. I believe it was around 67 they changed.
Old Oct 5, 2007 | 11:05 PM
five7kid's Avatar
An 010 casting is large journal. It first appeared in the '69 model year.
By the time they started casting "5.7" into the block, they weren't making the 327 anymore. And, as I said, they used the same casting for both the 327 and 350 (and, I might add, the '69 302). It didn't know what it was going to be until the crank and pistons showed up.
Old Oct 5, 2007 | 11:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 327 or 350?
Why would you want to use a non-roller block from the 60's in your late-model car with a roller block in it??
Old Oct 5, 2007 | 11:28 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: 327 or 350?
You could add "one piece rear oil-seal" as another advantage of the later (87+) blocks.
However, if you want "all out power", the blocks from the 1960s had a higher nickel content which made them stronger and better able to handle high power levels.
Old Oct 5, 2007 | 11:53 PM
joshh44's Avatar
Engine: engineless
Re: 327 or 350?
thanks for the info
i whent to take some photos of the block but batteys dead!!!
i just got to take it in to a shop to check if there are any cracks in it.
im hoping there isnt.
anyways thanks for the info again
TX-SleeperC5
Feb 24, 2016 01:34 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
Formula_88AE
Sep 3, 2015 01:47 PM
