grinding stones
Old Oct 4, 2007 | 12:39 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
grinding stones
what kind of grinding stone is used to clearance the block for strokers? Basically, to cut into the iron efficiently.
All I see are aluminum stones says good for cutting steel and other metals, does that include iron?
Old Oct 4, 2007 | 12:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: grinding stones
You don't use a stone, you use a carbide cutter.
Old Oct 4, 2007 | 12:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: grinding stones
Do you know where I can get those at? I tried Home Depot and Lowes, Maybe I am looking in the wrong places.
I remember a few years back when I did my first clearancing for my other 383, It was at my buddies house and I was using some cone shaped thing on the air tool that worked extremely well. I don't remember the material, probably some king of 'carbide'.
Old Oct 4, 2007 | 01:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: grinding stones
You should be able to find them at any hardware store.
Old Oct 4, 2007 | 01:27 AM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
Re: grinding stones
i used a cheap dollar store stone kit and an old a$$ drill, took a good while and stones didnt last but it worked. just make sure you clean up the block after.
Old Oct 4, 2007 | 04:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: grinding stones
carbidebur.com has the best prices. I think they shipped 'em to me pretty fast. They were so cheap on there that even after shipping and border fee's it was SIGNIFICANTLY cheaper than buying them locally ($40 per).
A 3/8" ball nose cylindrical one, on a short stick (you don't need the 6" long one) should do it. It's also handy to have for your cylinder heads (although a steel cutting one would load up with AL quickly...)
Old Oct 4, 2007 | 04:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: grinding stones
I like a cylindrical one better for that.
Old Oct 5, 2007 | 04:44 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: grinding stones
Look at McMaster Carr. They're a supplier of almost anything related to manufacturing. I bought my carbide burrs for $15-25 ea depending on the style and size. I think a 1/2" oval is about right for this type of grinding. And you'll also need a die grinder. Harbor Freight has pretty good ones for about $20. You can find both these suppliers online.
One more tip if you're grinding on aluminum. Spray the burr and the manifold (or head or whatever) with WD-40. This will keep the aluminum from sticking to the grinding burr. Re-apply every port or so. Use a wire brush to clean the burr or a pick if it gets loaded up bad.
Last edited by antman89iroc; Oct 5, 2007 at 04:47 PM. Reason: Automerged Doublepost
Old Oct 5, 2007 | 09:28 PM
Beast407's Avatar
Re: grinding stones
Other good sources are Rutland Tool and Travers Tool.
Old Oct 6, 2007 | 12:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: grinding stones
any kind of local name stores that would carry them?
Old Oct 6, 2007 | 01:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ace Hardware.
Jorlain
Oct 8, 2015 01:57 AM
hdis2002
Sep 8, 2015 02:52 PM
InfinityShade
Sep 5, 2015 06:38 PM
solocus
Sep 2, 2015 12:14 PM
hokis
Aug 9, 2015 03:57 PM
