installing a manual oil pressure guage
Old Oct 6, 2007 | 12:37 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
i just put in a new crate engine, and after running it for about 30 min, the op started to fall then nothing, when i rev it goes up slightly but not enough.. does this sound like my sender may be bad? also i want to put in a manual guage to test, and i have a TPI and the sender is a pain to get to ... is there aanother location i could try?
Old Oct 6, 2007 | 03:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: installing a manual oil pressure guage
You can use the port on the back of the block near the distributor, on the side above the oil filter, or on some blocks there's a port above the water pump.
Old Oct 6, 2007 | 05:29 PM
Axle/Gears: 4.10
belive the port on the back is where the current one is. i hope i have one near the front that i could tap into. thannks
Old Oct 7, 2007 | 10:09 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I depend more on the manual psi gauge and it's easilier to access all oil related sensors my car.
https://www.thirdgen.org/forums/tech...il#post2618182
Old Oct 8, 2007 | 02:38 PM
Axle/Gears: 4.10
what did you tap into to make that? did you just run a line from the rear of the block, where the sending unit was?
Old Oct 8, 2007 | 07:24 PM
Axle/Gears: 4.10
ll, turned out to be the sender, i just taped into where that was.. it was alot eaisier than i thought it would be,
Old Oct 9, 2007 | 09:29 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
To answer your questions; It's just a piece of stock alum with one bore down the center and npt tapped for the oil line on one end and the PSIG on the other, then the 2 taps in from one side for the sensors.
I did this when the sender failed, at my age anything that keeps me from having to get under car, or to get at things you can't see is a blessing.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
