Car wont start
Old Oct 8, 2007 | 12:02 PM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
Car wont start
I have an 84 camaro, 350 carburated engine. A b&M megashifter...i think its giving me some issues with the neutral saftey switch....but im not quite sure if anyone had a bad neutral safety switch. Had this shifter in about a year. was at the drags i guess the switch came loose and didnt want to start, i pushed the switch in so it can make contact to the metal of the shifter and it started. But now it wont start like that no more. I can start it by making contact on the starter's pos and neg posts... Just wont start by the key. It doesnt crank, it doesnt click, it doesnt do anything. Anyone got any ideas on what it can be? And if anyone have a b&M shifter instructions and can scan the pages for me id appreciate it.
thanks.
Old Oct 9, 2007 | 02:05 AM
Car: 84 camaro z28
Engine: 350 Carb
Re: Car wont start
TTT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! need car to start correctly
Old Oct 9, 2007 | 04:52 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Car wont start
changing the neutral switch sounds like a good place to start,but first check and see if you blew a fuse
Old Oct 9, 2007 | 06:13 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Re: Car wont start
jumper the purple and yellow wires from the factory shifter plug if it starts ok. change out the micro switch. B&M website has shifter install directions. DJ
Old Oct 9, 2007 | 08:20 AM
Car: 84 camaro z28
Engine: 350 Carb
Re: Car wont start
do i connect the yellow and the purple together? Thanks alot for the info about the b&M website helps alot. need to see what is the starting wires and everything.
already checked the fuses. It could also be the relay.. thanks for helping, im open to other suggestions as well.
and also what is the micro switch u r talking about?
Old Oct 9, 2007 | 08:45 AM
Car: 84 camaro z28
Engine: 350 Carb
Re: Car wont start
Ok i connected the yellow and the purple wire as u told, it started right up. Is it ok to leave them connected for the time being. or just for the start? Im thinking its the relay, i dont even have my reverse lights on anymore . But thanks, atleast i can move my car
Old Oct 9, 2007 | 09:09 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Re: Car wont start
You can leave them connected just make sure the car is always in park as it will now start in gear. the micro switch is the neutral safety switch on the side of the shifter which is where your backup light switch is also located. the last page of the B&M info tells you how all this works. I just got done installing a Megashifter and went through the same problems just make sure the switch is contacting the correct spot on the shifter. Good Luck DJ
Old Oct 9, 2007 | 09:53 AM
Car: 84 camaro z28
Engine: 350 Carb
Re: Car wont start
yea, it is making the right connection. Probaly broken u think?
Old Oct 10, 2007 | 07:15 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Re: Car wont start
If you have access to a multi meter check the switch for continuity. if there is none the switch is bad. These are available at any B&M dealer.
part #130-80629 approx $15.00
Old Oct 13, 2007 | 12:06 AM
Car: 84 camaro z28
Engine: 350 Carb
Re: Car wont start
Part came in today, The relay was the problem...this is my 3rd relay case in a half a year....they need to make a stronger relay
Old Oct 13, 2007 | 04:32 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Re: Car wont start
Glad you got it going. Happy Motoring... DJ
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
