stock drive belt size?
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: stock drive belt size?
27/32" X 98" 6 rib
Part Number: 5060980 from dayco
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
98" are you serious?
my irocz with AC, smog and all that was 94.5" or the 5060945 dayco
it it worked well for smog delete with underdrive pulley and stock alternator. now i use a 94.0 " for overdrive alternator pulley
that what the comper at advance auto says ?!?!?
Car: 89 Iroc-z
Transmission: TH400
interesting... i dont know if they ahd different setups or not, my 89 has AC on passenger side and alternator on the drivers side of the motor
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
The accessories are in the exact same place on the 88 as they are on the 89, but the 88's used a longer belt that was routed different. I ran an 88 belt on my 89 for a while and it worked fine, just had to route it differently. Luckily I had an 88 upper fan mount sitting in the garage with that sticker that shows the belt routing.
Car: 89 Iroc-z
Transmission: TH400
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
knight72
Aug 10, 2015 09:32 PM
