Condensation on rocker arms???
Old Oct 10, 2007 | 12:58 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
I have started my motor several times after getting it back together without fully reaching operating temperature and for a maximum of about 2 minutes at a time, I have been trying to get the timing and idle right. I pulled the valve covers to recheck the valves and make sure they were not too tight or loose. When I pull the valve covers I discover condensation on the rocker arms, (both heads), it looked just like the outside of a cold drink on a hot day and a small amount of water in the oil in the top of the head.
After searching and reading other entries it appears I have never had the motor hot enough to "burn off" the water vapor build up. Is this a correct diagnosis?
Also no noticable water on dipstick or oil in radiator, and no significant loss of coolant.
Old Oct 10, 2007 | 01:33 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Condensation on rocker arms???
Well....if you were up north i think i would say there is a problem, but you are down here in hell hot Texas so it is possible, how much water is in the head? PICS.
Old Oct 10, 2007 | 02:43 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Sorry I dont have any pics, but I would guesstimate that there was about a tablespoon full(total) in each head. Total being on rocker arms and in oil, most of it was on the rocker arms.
Old Oct 10, 2007 | 03:19 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, dry it all off, run it again, then see if it is still there, if so i might be worried.
Old Oct 10, 2007 | 02:20 PM
Pocket's Avatar
Car: 91 Trans Am
Check your oil and monitor the coolant level
This doesnt sound good at all
Old Oct 14, 2007 | 04:50 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
I drained the oil today and it had a noticeable amount of water in it. I drained the coolant and didn't notice much oil at all. I should have mentioned previously that I am using FelPro 1094 coated head gaskets, I installed them dry and I had to stab the heads a couple of times to line them up. Did I screw something up when installing the heads, I did block sand, and wipe with brake clean the block and the heads. Just curious if anyone else has had to "redo" a 1094 gasket install.
I am going to replace the oil and coolant and see if it happens again, if so I guess I'll be tearing it back down to find the problem.
Old Oct 14, 2007 | 06:31 PM
Pocket's Avatar
Car: 91 Trans Am
Pull the heads
Head gasket is dumping coolant in the cyls and oil
This is NOT something you can wait on
Old Oct 14, 2007 | 09:22 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
I am not really in a big hurry to pull the heads. This is not a daily driver for me so I have all the time in the world to work on it. I am hoping, but doubtful that the oil pan got some water in it when I was making all my changes. I had to drop the oil pan a bit to put the camshaft in and it was "open" for quite a while (at least a week). I just want to see if I get lucky, I'll let run for a minute or two and then pull the valve covers to see if I get the same result. If it is the same result then oh well back to work, if not though time to continue on.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
New2Chevy
Sep 28, 2015 12:35 AM
