has anyone seen this roller setup
Old Oct 15, 2007 | 02:47 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
http://cgi.ebay.com/ebaymotors/ws/eB...tchlink:top:us
is this the real deal or what?
I would like to use this to install all the stuff from my roller block into the old school block I am going to use but I just dont know
Old Oct 15, 2007 | 02:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: has anyone seen this roller setup
your just getting a pdf file that shows you how to convert 87 up lifters for use in pre 87 blocks??
wonder how that works and if its safe to modify stock lifters for that use
Old Oct 15, 2007 | 04:08 PM
Yeah, people post that all the time.
It has nothing to do with "modifying lifters".
All it is, is "instructions" on how to hack up a pre-roller block to accept some factory roller lifters (NOT the ones you have now).
It involves, among other things, drilling into the oil passage that feeds the main bearings, and installing 3 leaks that penetrate that passage. Pretty scary stuff. Requires a fair amount of hacking on the top of the lifter bores, as well.
I suggest you don't take it too seriously; and rather, if you want to use your factory roller stuff, find a factory roller block for it.
Old Oct 15, 2007 | 04:09 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you actually wont be moddifiying anything besides the block... basically 3 holes in the oil passage need to be drilled and tapped then the area around the lifter bores needs to be made pretty flat to support the dogbone then you have to options for cam endplay... you can use a thrust bottun or you can make provisions for a thrust plate... like the OEM setup...
how ever you CANNOT USE regular V8 ROLLER LIFTERS... they MUST BE from a 4/6 cyl engine... i would go with the 6 cylinder ones... lot less to remove than a 4 cyl... if you are going to the junkyard...
it should also be noted that this setup isnt viable for lifts in excess of .510
as the lifters will fall to far into the bores and slip out of the dogbones
TX-SleeperC5
Feb 24, 2016 01:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
customblackbird
Oct 1, 2015 04:30 PM
TexasMaro
Sep 15, 2015 06:50 PM
RyanJB
Sep 14, 2015 03:39 PM
