Stainless Steel motor mount through bolts?
Car: Pair of 92 Z28s
I like all new hardware, especially if its stainless steel. Anyway i got some of these from summit and they are about 1" too short...kinda pissed about that.
Other then just new bolts from the dealer anyone else know where to get some new stainless steel bolts made for the mount mounts?
http://store.summitracing.com/partde...5&autoview=sku
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
Re: Stainless Steel motor mount through bolts?
i got my stainless steel bolts from ace hardware + they carry sizes up to like 6" so that would be good for a motor mount.. hope that helps
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't forget about the hardness rating. I believe that 10.9 is the stock rating. Some stainless comes in grade 5 and other stainless comes in grade 8. I had to go to a specialty bolt store to get new motor mount through bolts. Even then all I could get was gold washed zinc grade 8 bolts.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they have been holding up on my engine for a while i use them for the threw bolt in the mount that bolts the engine mount to the chassis mount also i am using them to bolt the chassis engine mount to the chassis
Terrell351
Jun 13, 2021 01:13 PM
NBrehm
Aug 5, 2015 07:57 PM
