650hp 383 build
650hp 383 build
Hey guys I'm new to the forum I just bought a 1990 I-Roc and i am going to build a 383 stroker for the car, I'm looking to get about 650 to the ground and and run 10's going to be a overall fun car some street and some track use. Looking for ideas on cam, heads, pistons, intake and exhaust for the car as well as a general use transmission that can handle 650hp.
Thanks.
Chris
Thanks.
Chris
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 650hp 383 build
You'd need a power-adder. 650 N/A HP to the wheels isn't going to be even remotely streetable.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 650hp 383 build
You could do it with a 2 stage NOS kit but $10k will not be enough to keep such a small engine together. Making that much power in a SBC means nothing about the engine will be factory or very streetable.
Having an engine with that much power means not just the transmission but the whole powertrain and suspension need to be able to handle it. If you can't get the power to the ground, you won't get into the 11's.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: 650hp 383 build
here ya go, http://www.ohiocrank.com/enginekits.html, buddy bought one of the 620 super class motors, 900hp for 10g is a steal
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 650hp 383 build
The basic motor is only part of the cost. There will be a lot of associatied parts to go with it to hold and make that power. Fuel system will be one. Exhaust system will be another. The parts and money will add up fast.
Car: 1979 Malibu
Engine: Blown LSx
Re: 650hp 383 build
price out the compnents alone its a steal, the add on parts will come with anything you build
Car: 1989 GTA
Engine: 369 TPI
Re: 650hp 383 build
The point we are trying to make is that be had better budget a lot more money than 10K.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: 650hp 383 build
Look at my sig, I am hoping it will produce in the 600hp range at the flywheel. I know It's well over 10k. It's only heads and charger shy of being finished which of coarse, is a huge chunk of change, around 4 grand not to mention I have to put the intercooler kit together myself.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
