dual gate 2 problems
Old Oct 26, 2007 | 02:51 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
i just installed everything with the shifter and it doesn't work. My shifter doesn't shift at all. all it does is slide back half way and stops. I can't even drive my car. My steering column also locks out and it's hard to get my key out. I don't know what is wrong. Is my shifter defective? I am getting really pissed off because I just spent some good money and it doesn't even work.
any suggestions?
Old Oct 26, 2007 | 03:52 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: dual gate 2 problems
There was a second cable on your stock one, (hooked to the shifter button) it needs to be pulled I believe to release the lock on the key cylinder. Find a way to keep it pulled out, that will solve the key deal. As for the new shifter stopping, try adjusting it, place the shifter in it`s "N" position and then click the trans to it`s "N" position, them make the cable the right length.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
