383 stroker what compression ratio for pump gas
Old Oct 28, 2007 | 10:04 AM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im building a 383 stroker with 6" rods with this kit http://cgi.ebay.com/ebaymotors/ws/eB...155158473&rd=1
and i want to run on pump what would be the best compression ratio im going to be using edelebrock pro flo 3500 injection and im trying to decide on a trick flow head combo
Old Oct 28, 2007 | 10:22 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 383 stroker what compression ratio for pump gas
10.5:1 for the street 11:1 if it will never see the street
Old Oct 28, 2007 | 12:51 PM
lbman0007's Avatar
Car: 1986 Chev Camaro
Transmission: Th350
Axle/Gears: 10 bolt 3.23 posi
what type of octane fuel do you need for 11:6.1 ?
Old Oct 28, 2007 | 12:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As much as needed to eliminate detonation under load. There is no magic number based on a compression ratio since each engine is different.
Some engines can run 92 octane on 12:1, some engines can only do it at 10:1.
Old Oct 28, 2007 | 02:36 PM
Car: 82 z28
Transmission: TH350
so would it be best to go for 10.2:1 or 9.6:1 for this it will be a daily driver i dont want to go higher than 93 octane but i dont want any chance of detonation
Old Oct 28, 2007 | 02:41 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
9.6:1 is better. the lower the compression usually makes it burn lower octane. best bet it to ask to company you got the kit from or the shop doing it for you.
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
