oil pan problems!!! Please Help
Old Nov 1, 2007 | 02:14 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I am putting an old school 350 in my 91 bird and I need to know which oil pan to use
from 82-85 gm only used the 305 with a passenger side dip stick. I need a two piece rear main seal oil pan with the dipstick on the drivers side with the provision for the exsaust
I was looking at the 70 style oil pan for camaros and birds and it looks right but I wanted to make sure before buying anthing.
please help so I can button this one up
Old Nov 1, 2007 | 02:19 PM
Re: oil pan problems!!! Please Help
The pan for a 70s Camaro will work fine. Clears everything.
Not sure about the "exhaust" thing?
Old Nov 1, 2007 | 02:35 PM
jamon8's Avatar
Engine: 350 tpi
I was talking about the way the exsaust tucks up by the oil pan and keeps us third genners from using a stock oil pan
Old Nov 1, 2007 | 02:43 PM
Really?
What kind of pan did they come with, if not stock?
I ran this one for many many years, on a 400, with the Moroso Teflon-coated windage tray; with the stock L69 exhaust, then Edelbrock TES, then SLP 1¾". Seemed to work pretty good and fit everything just fine. And it's just an old stock pan for early 70s Camaros. Note however, that it holds an extra quart of oil.... 5 quarts IN THE PAN, plus the filter.
Old Nov 1, 2007 | 02:58 PM
jamon8's Avatar
Engine: 350 tpi
here is a pic of the stock oil pan that came off most 350's and the black oil pan is the one that is used on our cars with the indentation for the exsaust
Old Nov 1, 2007 | 03:08 PM
That's a truck pan. Stock for a truck. Has nothing to do with being a 350; they used that on 400s and 305s IN TRUCKS too.
The other one is a A/F/G body pan. Stock for all of those (our cars of course being F bodies).
You're right, a truck pan won't fit our chassis.
But "stock" doesn't tell the whole story; as SOME "stock" pans fit our cars just fine. Like the 70½ Z28 pan I linked you to.
Old Nov 1, 2007 | 04:07 PM
jamon8's Avatar
Engine: 350 tpi
thank you for all the good info
I went to a buddy of mine while my girl got a perm and bam he had the oil pan I needed
keep the third gens alive and pumpin
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
