car shuts off while driving
Old Nov 3, 2007 | 10:10 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I did a search on here and didnt come up with anything related to what is going on with my car. I can start it, and drive for about 3 or 4 minutes and the car will cut off. Then it takes me anywhere from 10-20 minutes to get it started again.
It isnt a charging problem, I kept my eye on that. I hear the fuel pump engaging so im getting the pressure. I made sure all spark plug wires are on good and everything is plugged into the distributor and coil. I recently replaced the coil with MSD's coil. The grounding problem i WAS having isnt a problem anymore. That was the first thing I checked.
When I do get the car started again, it smells REALLY rich. Ideas? I was thinking maybe the fuel filter?
Old Nov 4, 2007 | 09:15 AM
Car: 92 Camaro
Axle/Gears: S60 373
Re: car shuts off while driving
nobody?
Old Nov 4, 2007 | 05:28 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
it could be flooding from cranking it so much. check your coil when a coil is bad some times it works and when it gets hot it stops
Old Nov 4, 2007 | 05:37 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
check the coil, the msd coils are not the highest quality (I know at least 10 people who have had defective ones, and I had 2 defective ones)
Old Nov 4, 2007 | 06:05 PM
Car: 92 Camaro
Axle/Gears: S60 373
if this coil is bad, then this would be my second MSD coil that is trash
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
