piston/rods pressed or floating
Old Nov 3, 2007 | 04:48 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
i am building a lt1. i am stroking it to 383 i was wondering if it would be any better to use floating pins. or will this set off the knock sensor thanks
Old Nov 3, 2007 | 05:12 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: piston/rods pressed or floating
Hi,
A little less side wall loading, a little less friction and
ease of assembly and disasembly.
I've always used them for the latter
Good locks and attention to assembly.
Either way good
Old Nov 3, 2007 | 07:03 PM
ok thanks. i was thinking it would be less friction. i didnt even think about side wall loading. but your right it makes sence
Old Nov 6, 2007 | 12:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I doubt you'd notice any difference in friction or side loading. With a pressed pin, there's no locks to fail. With a floating pin, you don't need any special equipment for assembly and disassembly.
Old Nov 6, 2007 | 01:18 PM
yea thats another reason why i am considering floating pins for this .easy to disassemble. usually i use pressed on the fuel injected motors cause thats what they come with. but i have built a few with floating pins most of them were carbed thought. wich one is lighter do you know?
Old Nov 6, 2007 | 01:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You wouldn't notice a difference in weight, either.
Old Nov 6, 2007 | 05:13 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
The only advantage to pressed that I can think of is if you are the machine shop getting paid to do it. The very small amount extra that the rods cost for a floating pin pays for itself the first time they are assembled (by you - for free). However not all pistons come with the locks or grooves for them.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
86maro_252
Oct 10, 2015 06:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Springster
Sep 13, 2015 01:38 PM
