Couple of questions.
Old Nov 3, 2007 | 05:28 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Today I went to change the oil in my car and noticed a wire hanging down on the passenger side behind the crossmember. Can someone tell me what this is? The second picture shows where I think it goes between the number 6 & 8 plugs, but I am not sure. Is there anything missing like a plug or does this wire just push straight in? Any help would be appreciated.
Also, does anyone know the size of the bolts that hold the rubber mount to the back of a 700r4?
Attached Thumbnails Couple of questions.-chris-car.jpg   Couple of questions.-chris-car2.jpg
Old Nov 3, 2007 | 05:35 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Couple of questions.
what color is the wire?
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
tsu temperature sending unit and its broke well atleast broke enough to replace
Old Nov 3, 2007 | 05:46 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
basically that is a switch to turn your radiator fan on/off
Old Nov 3, 2007 | 05:55 PM
Could also be the knock sensor wire; that sensor is right above the oil pan, just in front of the starter.
If the wire is dark green, it's for the fan switch. Blue, the knock sensor.
Old Nov 3, 2007 | 09:57 PM
Pat Hall's Avatar
Probably the fan switch. You can see the knock sensor wire is still hooked up in the first picture. You can go to the junkyard and snip a good one off a car there, or buy a brand new one w/pigtail from TPIparts.net. Those connectors get broken all the time since they're a squeeze type connector, and they get really brittle over time from being so close to the exhaust manifold. The knock sensor uses the same connector, just a different color. It's white instead of black. They're usually easier to find in good condition on a junk car since they're not exposed to as much exhaust heat compared to the fan switch connector.
Old Nov 3, 2007 | 10:13 PM
Guest
Guest
Posts: n/a
In the first pic you can barely see the fan switch. There's nothing attached to it.
I'd advise getting a new connector.
Old Nov 3, 2007 | 10:15 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Another source for wire parts is www.eficonnection.com Might want to keep it as a backup reference.
Old Nov 4, 2007 | 09:26 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
If it is the fan switch then that would explain why it hasn't been turning on when it gets hot. Although I usually turn the A/C on to make sure it won't get hot in traffic.
Thanks for all the replies I will try to get it fixed soon.
Old Nov 5, 2007 | 12:39 AM
Pat Hall's Avatar
Yeah, that totally makes sense. Turning on the A/C overrides the switch in the head. I guess it's a good thing they engineered it that way. At least you still have a way to get the fan to come on.
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
raymondandretti
Sep 27, 2015 06:43 PM
