Rear end gears have an effect on chassis dyno numbers!?!?!?
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I was thinking about this today, so hear me out. A chassis dyno measures torque, nothing more. The horsepower figure is a numerical derivitave based off of torque. This equates to....
torquexRPM/5252= HP
Consequently, at 5252 RPM, torque and horsepower will always be equal.
Now, lets say that my engine makes 300HP and 300TQ. On the dyno the torque does not get multiplied by the fourth gear ratio of the transmission. Let's use a 1.0:1 (assuming 4th gear) ratio. So there is 300 ft lbs of TQ coming out of the transmission(minus frictional losses) and going into the read end. Let's assume that the rear end gears are also 3.0:1. That means that there is 900 ft lbs of TQ available to both axles/wheels. The chassis dyno sorts out all the mathematical formulas and spits out your rear wheel numbers. Now, let's say that all you did was change the rear end gears to a 4.0:1 ratio. That would be...
300TQ(on motor) going into the 1.0:1 4th gear which is still 300, and goes into the 4.0:1 rear end gears and comes out as 1200 ft lbs to both axles/wheels. Now, would the chassis dyno spit out a different(higher) number because the available torque has increased?? Also, seeing as how the horsepower figure is based off of a now higher torque number, could it be safe to assume that the rear HP figure would be higher also??? What do you think? I was just kickingthis idea around and figured I would post it up and get some comments. The reason why I am asking is because it will be time to do some chassis dyno tuning for me pretty soon and I have an open differential with 3.42's in the pig. I plan on running a 9 inch ford rear end with a posi and 3.73's. If I get my car tuned with the 3.42's and then get the other rear end, I don't want to have to get it tuned all over again because the rear end gears threw off the numbers...
torquexRPM/5252= HP
Re: Rear end gears have an effect on chassis dyno numbers!?!?!?
I think it uses mph vs rpm vs time to figure out how much torque is produced. I dont know the exacts, but I am pretty sure thats how it trys to keep things accurate.
Regardless of gear, your horsepower reading should be the same if not close.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ppl will argue that it wont change the numbers but i've seen it happen on a dyno where a guy lost 15lb ft of torque peak with higher numerical gears. based on my theory i think it was software error
some dynos i think calculate the speed at which the roller moves and the time to get it accelerating to its peak acceleration. somehow it takes that to calculate tq, but i'm not sure. deeper gears will make the car run thru the power band quicker and should make the roller move quicker but the time it takes to do so should decrease. thus the software should calculate no change in dyno numbers
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All chassis dynos use the speed of the wheels to correct the torque reading. Any differences are due to differences in drivetrain loss, test conditions, or normal measurement error.
Without correction, you'd see differences even just from changing the tire size.
Transmission: 4L80E/4L80E
Forget which one it was, but a couple of years ago a mag had an article about determining horsepower. Engine dyno was the most accurate. In decreasing order, the next most accurate methods were 1/4 mile performance, engine equipment, and chassis dyno.
Car: 89 Iroc-z
Transmission: TH400
indeed, because a car that runs 12's at 110mph at a weight around 3600lbs should put down more than 308whp. my buddy was abit dissapointed in those numbers but the car runs faster than what ppl would think based on those figures
Car: 1988 Trans Am GTA
Engine: 350 4BBL
A brake dyno measures actual torque produced by the wheels and measures horsepower at a constant rpm speed. It is much more accurate at determining actual net horsepower because acceleration and inertia are not a factor. These are used to measure horsepower on semi trucks.
The idea with inertia dynos is that the drivetrain rotating mass that must be accelerated will make a given car faster or slower at the dragstrip also. This is why drag cars use aluminum driveshafts, 9" converters, light flywheels, and low mass tires. The inertia dyno will see changes from this where a brake dyno would not.
Confused yet?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Fascinating thread...
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Good responses and info in this thread.
Generally, steeper gears lose a tiny bit of efficiency and will show just a little less hp on a chassis dyno.
Horsepower (rate of work) is the direct output from an inertia dyno. Torque is calculated from hp and engine rpm, not roller rpm.
Orr89, If he's putting most of his power to the ground right off the line, then that 308 rw number sounds about right to me. My 3950 lb car shows around 310 STD rwhp on a Dynojet and runs 12.3's at 107+ in good air. It 60's about 1.60.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
When I had my 2000 Tahoe on the dyno they had to run it in second gear (A4). Reason was the tires on my Tahoe did not like the 120+mph of the dyno pull in 3rd gear. Anyways there was an 18% correction factor to be added to the horsepower rating because of the 2nd gear run. So the lower the gear ratio the more horsepower you would be "losing" on the chasis dyno.
OK, I'm confused.
My truck stock had 3.73 gears and 265/75/16 tires.
My truck now has 4.56 gears and 315/75/16 tires.
With the same engine, my truck would register more HP/TQ with the 3.73's and 265's? Because of the smaller tire diameter?
Engine: 383 Carb
Transmission: 4L60
In theory it won't read any differently.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
with the larger tires you would have more loss due to both tire friction and extra mass that needed to be accelerated.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
