Desktop Dyno help
Old Nov 10, 2007 | 11:04 PM
88bracketT/A's Avatar
Car: 88 Trans-Am
Engine: 406 SBC
Desktop Dyno help
Does anyone have Desktop Dyno and could run a combination through it? I just bought Virtual Engine Dyno and ran my combo on it and came up with 702 hp @ 6250 rpm and I know there is know way it's making that kind of power.
400 SBC 2 bolt with splayed 4 bolt caps 4.155 bore
3.75 eagle forged internal balance crank
Scat Pro Comp 6.0" rods
Keith Black forged flat tops # KB755
Dart Pro 1 230 cc heads. Angle milled to 56cc chamber 13.1 comp mild porting
Comp solid roller .630 lift Dur. 264I 270E @.050 part# 12-908-9
Harland Sharp 1.5 full roller rockers
Vitor E manifold #2978
Holley 850dp
Unilite dist 38 deg total timing on race gas
Hooker super comp full length headers - open
I haven't put the motor in the car yet. I thought it would be 575 to 600 max but if this thing is true I may have to rethink the rest of the drivetrain.
Old Nov 12, 2007 | 05:43 PM
Car: 88 Trans-Am
Engine: 406 SBC
Re: Desktop Dyno help
Anybody ?
Old Nov 12, 2007 | 06:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If someone was to do it they would need the flow numbers of your heads.
Old Nov 12, 2007 | 09:25 PM
Damon's Avatar
If you're talking about a 700HP small block you're well beyond what DD can accurately predict. At the 300-500HP level it's resonably accurate, but when you get into the really crazy combos it just doesn't have the intelligence to give you a good estimate. There's only so much you can do with half a meg of simulation code.
Old Nov 12, 2007 | 09:39 PM
Car: 88 Trans-Am
Engine: 406 SBC
Head flow is:
Intake 308cfm at .700"
Exhaust 207cfm at .700"
I know it's not going to be exact. Just looking for a rough ballpark even just to see if comes up close to what Virtual Dyno said
Old Nov 12, 2007 | 09:52 PM
Guest
Guest
Posts: n/a
630hp @ 6500
545tq @ 5500
Thats what it spit out to me.
Old Nov 12, 2007 | 10:03 PM
Car: 1989 GTA
Engine: 369 TPI
I just checked it on DynoSim. Came within a couple of horsepower to what MadMax has. 625/544
I used my Dart Pro One 200cc numbers for the lower lift flows on the head.
Old Nov 12, 2007 | 10:06 PM
Car: 88 Trans-Am
Engine: 406 SBC
Thanks alot guys I really appreciate your help.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
