car wont idle
Old Nov 18, 2007 | 04:10 PM
SLONOMO91RS's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
car wont idle
I have a 91 camaro rs 305 tbi and I cant get it to idle. when I start the car it will barely run, it shakes, the tach goes crazy, it will backfire, and it will try to die. I have replaced the plugs, wire, cap, rotor, coil, fuel pump, fuel filter, knock sensor, ignition module, fuel pump relay, map sensor, tps, esc, and nothing has helped. This is my daily driver and I need it running. Could it be the pick up coil? Anything will help me so much right now.
Old Nov 18, 2007 | 05:55 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: car wont idle
with all youve replaced ,id say youre on the right track, id check the iac first tho,make sure its clean,& check adjustment on it. tgo homepage explainshow to adjust, later jimmy
Old Nov 19, 2007 | 06:58 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
Re: car wont idle
I'd first check to make sure your plugs are in correct firing order. Then I'd check your timing and make sure you're not 180 out.
Old Nov 22, 2007 | 10:51 AM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Re: car wont idle
The car has been sitting at work for 2 days and I went in this morning and it started and ran good. I didnt do nothing to it. I can drive it but it will still cut out and backfire and the tach will go crazy. I noticed when it is idleing and I cut on the heat it will start to do it. Would this be ground problem? How could i test the grounds?
Old Nov 22, 2007 | 11:31 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: car wont idle
It's not as much as a ground problem as possibly a low voltage problem. The C100 connector which sticks through the firewall on the drivers side contains all the power for the injectors, fuel pump, etc. If theres not enough voltage getting through there (due to the tar) then it will run bad when other accessories are driven. If the tach is bouncing, then one or more of the cylinders is not firing. If it's backfiring, then it's the ignition system. Check the plug order on the distributor like they said. Check the timing too. If you've checked both of those and everything seems to be in order, use a spark tester and make sure there is an arc going to each cylinder. The cheap (~10.00) spark tester will come with instructions on how to use it.
The IAC wouldn't produce these symptoms. I had a bad IAC once. It'll either Idle really high (start at 1500 or so and continue to climb) or it'll be stuck in one idle spot. If when you start the car, it idles high, then slowly makes it's way down as it warms up, then your IAC is fine.
Old Nov 23, 2007 | 08:19 AM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Re: car wont idle
How would tar get in my connector? Also when the tach goes crazy, it will jump around but the car doesnt idle any differant.
Old Nov 25, 2007 | 03:54 PM
ntomsheck's Avatar
Car: 1989 GTA
Re: car wont idle
The C100 has tar in it (or a tar like substance) to keep water out of it. Sometimes it will melt and cover the connectors. How much does the tach jump around? couple hundred RPMS or a couple thousand?
Old Nov 25, 2007 | 06:15 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: car wont idle
have you checked to see if you have water in your gas
Old Nov 26, 2007 | 08:22 AM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Re: car wont idle
Most the time it just jumps a couple hundred. How can I clean the c100?
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
