Identify this weird squeal?
Old Nov 18, 2007 | 06:59 PM
tjcannon's Avatar
Car: 1981 Datsun 280ZX
Engine: MIA
Axle/Gears: 3.90 Quaife LSD
I know it's not a third gen, but I share your drivetrain. That has to count for something, right?
I have no idea what this is, but it sounds bad. You can hear it a little at 43 seconds in, then really bad at 1:07. It does it whether cold or hot. It is not a belt. It' seems to be coming from inside engine. It has oil in it. It's overheated 3 or 4 times in the past few days, and this started after one of those times. It's also been making some strange clicking noises that I don't know about.
Listen
Any ideas or advice on how to better identify it are welcome.
Old Nov 18, 2007 | 11:45 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Re: Identify this weird squeal?
Guessing... Waterpump?
Old Nov 19, 2007 | 10:11 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
x2... pull your belt off the water pump and start it up. if you still hear it, im guessing rod bearing.
Old Nov 19, 2007 | 03:13 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Sounds like a washing machine.
Old Nov 19, 2007 | 06:32 PM
atomicskr's Avatar
Might be a long shot but check to make sure all your spark plugs are tight. I've heard larger engines make the same noise and that was the cause.
Old Nov 19, 2007 | 08:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Take off the belt, check the water pump (spin it by hand) and the belt tensioner, tensioner pulley, and idler pulley. If none of those show a problem, put the belt on, run it to warm it up, take the belt off and start it and run it for a bit (careful to watch the temp, as the water pump wont be turning) and see if the sound is there.
Old Nov 19, 2007 | 09:01 PM
TransAM Joe's Avatar
sounds to me like a wiped out bearing or two.
Old Nov 20, 2007 | 08:54 AM
QuickStyle's Avatar
Car: 91 Z28
now that i think of it, i remember my smog pump making a similar noise. if you are running one, you might want to check that also, you need to break down where the noise is coming from by removing the accessories from the rotation of the engine.
Old Nov 20, 2007 | 03:12 PM
tjcannon's Avatar
Engine: MIA
Thanks for all the suggestions!
Just so everyone knows, I took the intake off to check the lifters because the squeal stopped but there was a horrible racket still. I found lots and lots of little goldish-copper colored flakes in the oil valley. Every single on of my hydraulic lifters was stuck and the lifters were full of the gold flakes too. I've been in Iraq for the last 17 months, so I decided to treat my engine to some new components after it gets magnafluxed. It's at the machine shop right now. ETA: 2-3 weeks. Future setup: who knows, but if you see a nasty sounding blue Datsun in the Fort Bragg, NC, area after January, be careful. ;-)
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Linson
Sep 21, 2015 01:08 PM
BWilcox
Sep 20, 2015 12:19 PM
