377 question? compression? streetable?
Old Nov 28, 2007 | 03:28 AM
FedorTheBear's Avatar
hey i have a 91' z28 and i am just seeing if there is any way to make it "streetable" at all? 13:1 compression now... any way to make it way lower and run smooth on pump gas? engine specs are as follows...
Dart 400 Block
Brodix Heads
Series steel crank 4340/3500 stroke
pistons are forged aluminum dome
keith black .080
six inch bullet connecting rods
titanium valves .080 bored
intake : 212. exhaust : 1.60.0
Pushrods: 7994 Competition cams
7.950 .080
lifters are full roller competition
cams and cam is full race competition cams
rings pro/series molly file fit
rocker arms aluminum full roller : 1.52
oil pump high colume / 7qt pan
13:1 compression
MSD-7AL-2 Pro-Race
MSD blaster 2 coil
msd programmable timing computer
1000 cfm carb
any ideas? if it is not a possiblity i have a friend that is selling a complete Lt1 from a 96 or so firebird for cheap that i may swap in.... thanks for any help.
Old Nov 28, 2007 | 11:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 377 question? compression? streetable?
Rebuild it with different pistons.
Old Nov 28, 2007 | 11:55 AM
kerplunk318's Avatar
a little off topic but why is there an a/c compressor on a 13:1 motor; doesnt really make sense to me
Old Nov 28, 2007 | 12:52 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you don't really have alot of vital informations/specs to tell though. we need to know the specs of the camshaft and cylinder heads. a 13:1 motor is pushing it no matter how you look at it. i'd pull the pistons and put in a set of 11:1's. with a camshaft with lots of valve overlap, you should be fine. i wouldn't expect to be able to daily drive it though. engines like this simply don't like the abuse of every day driving.
what kinda trans/converter/gear is the car running as well?
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
