Comp valve spring trouble
Old Dec 2, 2007 | 08:10 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Just got my heads back together, the problem is that the inner spring hits on the valve seals. the seals are brand new also. could this be a problem with the seals being on wrong?? and body else run into this problem? any help is appriciated!
thanks
Colt
Old Dec 2, 2007 | 08:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Comp valve spring trouble
Sounds like you might need to have your heads machined to work with different seals for those springs.
Old Dec 2, 2007 | 09:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which valve seals and which springs?
Old Dec 3, 2007 | 10:14 AM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
Ok i run CCA-986-16 and CCA-503-16 these came in a kit together so i imagine they are matched but i dont know. they are on vortec heads, i have already had the seats machined but maybe i need to have the guide bosses machined down also??? thanks.
Old Dec 3, 2007 | 10:25 AM
Sonix's Avatar
Car: 1982 Trans-Am
Uh, yea. Vortecs have notoriously tall FAT guide bosses. Bring the heads into your local machine shop and tell them what you've got. Common as the day is long. They'll know exactly what needs to be done.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
