158K miles, my pistons look pretty clean?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Some quick shot of my shortblock, i believe its all original
this winter i'm tearin down the motor to put on new heads and a bigger cam.
Car was running VERY lean tho so could that have burned off any carbon on the pistons?... they look pretty clean for 158,000 miles i thought. i was expecting more carbonized pistons.
the pics look like there is a burn mark in the shape of the combustion chamber but its not there, it is a light mark from the camera flash. the pistons look pretty clean
Car: 89 Iroc-z
Transmission: TH400
Re: 158K miles, my pistons look pretty clean?
not sure... maybe mildly ported L98 aluminums since they should fit my bill as far as power is concerned.
but if i can stretch some funds i'll pick up something else, maybe give those new patriot heads a shot but they are 1206 gasket and my HSR needs material added to the base to seal a 1206
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Thats good i need to get new heads, cam, intake, headers for my car then i think it will be good to go.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looks alot better than my poor old lg4, it had carbon potato chips stuck to most of the pistons, but its in a better place now...
ambainb
Apr 25, 2016 09:21 PM
mdtoren
Aug 16, 2015 05:45 PM
db057
Aug 11, 2015 10:11 PM
