What is this sound... High Pitched
Old Dec 5, 2007 | 12:44 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
My car only does it at wide open throttle. Tranny shop said my tranny was fine. At wot, my car makes a loud high pitched squeel. It does it until you let off. Normal driving, the noise is gone, it is just wot. Engine only has 11,000 miles. Is it a vacuum leak or a hose or something?
Old Dec 5, 2007 | 01:32 AM
RazinCayne's Avatar
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
Re: What is this sound... High Pitched
Sounds like a loose or bad belt..
Old Dec 5, 2007 | 05:45 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Why would it only make the noise @ wot? Wouldn't a loose belt make the noise at idle and in any gear?
Old Dec 7, 2007 | 02:04 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
does the car make the nosie in park at wot
Old Dec 7, 2007 | 02:12 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
No, it will make it if I put it in drive, Hit the gas and the brake at the same time though.
Old Dec 7, 2007 | 02:19 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
where does the noise seem like its coming from
Old Dec 7, 2007 | 05:02 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Font of the car, In the engine bay.
Old Dec 7, 2007 | 05:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In the old days, I would have said to check for a broken engine mount. That isn't as much of a problem with 3rd gens, though. Except for the tranny mount - did the tranny shop check that?
Old Dec 7, 2007 | 05:21 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
yes, they checked everything out and said it looked good.
Old Aug 23, 2012 | 05:39 PM
AJ Mc's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L 305 High Output
Transmission: Automatic 700-R4
Did this problem ever get figured out. I believe I have the same issue
Old Aug 23, 2012 | 07:00 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
[QUOTE=Bullydawg;3555280]My car only does it at wide open throttle. At wot, my car makes a loud high pitched squeel. It does it until you let off.
I think it was the tires squeeling???
Old Aug 24, 2012 | 01:35 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Could be a bad tensioner causing the belt to get slack and start losing it's position at higher RPM's.
Old Aug 24, 2012 | 02:15 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
It was that... 5 years ago... haha
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
