Engine Stalling
Car: 1987 GTA
Engine Stalling
Recently my car with a 350 TPI, AT and 6E Prom started stalling while coasting in drive mode. It starts right back up but doesn't want to maintain an idle with the tranny in drive. This car has headers, 24 PSI Accell Injectors, Edelbrock aluminum heads and an adjustable fuel regulator. A check of the service code gives the ECM as the source of the trouble. After reset, the same things seems to happen on rainy or damp days. A coil was changed in here but other than that, nothing has been done to ignition. I'm wondering if the trouble is in the ignition module of the distributor, a short in the PROM or fuel pressure problems.
Aloha,
Laser
Aloha,
Laser
Car: 1987 GTA
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Engine Stalling
Alldata shows Electronic Spark Timing (EST) error for code 42.
The fuel pump error code is 54.
Car: 1987 GTA
Re: Engine Stalling
Keep Your GM Car all GM!, What seems to have been the problem was a scoured and cracked rotor. I had replaced the rotor and cap about a year previously during another repair episode. As it turns out this Gold Plated Special was made in China. Needless to say, the rotor didn't hold up and occassionally caused the engine to stall at low idle speeds. There is carbon arcing all over the contact element and a slight crack running down the stem. It would re-start initially until it failed completely blocking any spark from the cylinders.
Hope this helps,
Laser
Hope this helps,
Laser
