350 rebuild
350 rebuild
Not trying to sound dumb but when you rebuild a engine if you get a NEW Crank you can use all standard size bottom end bearings correct? if you dont then you have to get the crank machined and use a undersize bearing?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 350 rebuild
That's exactly right.
Better to ask now and sound slightly dumb, than get it wrong and sound REALLY stupid later.
Magman
Sep 13, 2015 08:43 AM
Eric-86sc
Aug 24, 2015 09:01 PM
