Engine & Tranny Not Properly Connected
Old Dec 31, 2007 | 09:05 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
I was performing an oil change the other day and noticed the transmission and the engine were not completely joined together.
When i park there is a spotty line of oil right in the middle of the two.
Where can i get more bolts, what are they called and where from?
Is the black oil I see, more likely tranny fluid or engine oil?
All input appreciated...thanks!!!
Old Dec 31, 2007 | 10:56 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Engine & Tranny Not Properly Connected
im guessing that your real main seal is bad hence the oil seeping from between the tranny and engine.
Old Dec 31, 2007 | 11:24 PM
Car: 1988 Camaro SC
Engine: 2.8v6
You do understand, that i said there are bolts missing and they are connected fully...
I doubt its the rear main seal and more the lack of bolts or w/e between the engine and transmission....
Old Dec 31, 2007 | 11:31 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
but their is no fluid "exchanged" between the tranny and engine for their to be a leak if the werent "properly connected" unless the torque converter was pulled out and then the fluid would be red because it would be ATF. but then again if your torque converter was pulled out i dont think you would be driving anywhere. i mean yea i guess you could have some bolts missing but that would be the point of where it is leaking.
Old Jan 1, 2008 | 10:15 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It's common for the rear of the intake to leak and run down over the seam making a real mess.
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
