MELTED WIRE HARNESS PLEASE HELP... PIX!!
Old Jan 6, 2008 | 04:27 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
hey guys i finally picked up the 88 iroc. the guy showed me where it was melted so i toook pix of the wires and the 2 relays that go to them. here they are
Old Jan 6, 2008 | 05:09 PM
ljnowell's Avatar
Re: MELTED WIRE HARNESS PLEASE HELP... PIX!!
butt connectors? thats horrible. Solder and shrink wrap. no other method of repair is allowable IMO. The square one is the FP relay, if i remember. Not sure on the other. Been awhile since i messed with that stuff on one of these.
Old Jan 6, 2008 | 05:11 PM
Car: 88 IROC-z
Engine: LO3 V8 305
will those relays stop the car from starting? and running? also how do i tell if the relays are fryed? and how do i know if the ECM is bad? the wires only melted a few inches thats all. doesnt look like anything else melted
Old Jan 6, 2008 | 06:55 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
maybe the 3-wire with the large red wire is going to your o2 sensor
Old Jan 6, 2008 | 06:56 PM
Car: 88 IROC-z
Engine: LO3 V8 305
Old Jan 6, 2008 | 08:23 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
well if its for the fp like ljnowell said then yeah it will keep it from running, no fuel, no combustion. As far as the rest goes you can either trace it and look for more melts, or fix those 2 and hope for the best
Old Jan 6, 2008 | 08:25 PM
Car: 88 IROC-z
Engine: LO3 V8 305
well i will be lookn for more melts but it doesnt seem like there is more., also can u guys tell me where these pig tails are suppose to go? and does any1 have a pic of the fuse block on the inside of the passenger side fender.
Old Jan 6, 2008 | 08:36 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
the one top pic the square connector 3 pic down the right connector... there are 3 relays on the driver firewall that are interchangable. since yours is an 88 its a MAF car. one is a MAF burnoff relay, one is the MAF power, and one is the fuel pump relay, they all look the same and they all are interchangable. u well need them all for the car to run! sry man
without the FP relay the TPI fuel rail wont pressurize or run. the MAF power wont turn the maf on and they car wont start and if it does its gona run like crap, wihtout the MAF burnoff relay the car will run but u will throw maf burnoff relay code and the car wont perform good.
those connectors are ok for a quick fix but i wouldnt do any electrical work unless u soder and shrink wrap it... thats the only and best way
im not sure wat the last pic right above is for
Old Jan 6, 2008 | 08:38 PM
Car: 88 IROC-z
Engine: LO3 V8 305
the car is a TBI . and i have got new relays. i just need to know where that last pic goes to. and how do u know if u have fiuel pressure?
Old Jan 8, 2008 | 04:44 AM
Pat Hall's Avatar
Yeah, you need to hook relays up to the connectors in the first pic. The square one is the fuel pump relay. The round relay is probably for the cooling fan. The connector in the last pic looks like the ecm/fuel pump fuse. Need to put a 20 amp, blade style fuse in that one. I would imagine it will start and run once you hook up those relays and put a fuse in the connector by the overflow jar.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
