vacuum problem
Old Jan 8, 2008 | 11:20 PM
76birdman's Avatar
vacuum problem
i recently aquired an 89 firebird 305tbi 5-speed. The problem is almost all the vacuum lines are broken. The car starts and runs but as u can imagine with problems. Is there somewhere that will have the routing clearer than the auto zone website?
Old Jan 9, 2008 | 06:45 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
Re: vacuum problem
get a haynes or chilton manual, I recommend the chilton book though, it's worth the extra cost.
Old Jan 10, 2008 | 09:56 PM
76birdman's Avatar
Re: vacuum problem
thanks for the input. Of course i have a haynes but it doesnt show a vacuum diagram. I actually found it on the auto zone website. Thanks alot 4 ur time. I appreciate the knowledge of everyone on this website, theres so much info!
Old Jan 10, 2008 | 10:37 PM
Fldopp16's Avatar
Car: 89 IROC-Z
Axle/Gears: 3:42
Re: vacuum problem
I've found that vacuum in general is just difficult to find help with. One thing that I may suggest is just looking for high resolution engine bay shots that may be able to give you a general idea of what things should LOOK like; of course, make sure engine is the same configuration as yours. (Same mods, same fuel setup) I would also suggest doing what I did, and buying color coded tapes to wrap around the mating end of the lines so you know what goes where when it comes time to put it back together, because believe me, you may tell yourself that this is the last time you have the thing taken apart, but it's not ; )
Old Jan 12, 2008 | 01:21 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: vacuum problem
You might try searching for vacuum diagrams in this board. Someone posted a few detailed diagrams for various years recently. You can also find some diagrams in the FAQ board also.
Dave
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mustangman65_79
Aug 8, 2015 12:07 PM
