will this work???
Old Jan 9, 2008 | 09:47 AM
72 rs's Avatar
will this work???
im new to all this so please be patint with me. i have a 92 rs with a tbi 305 that needs a new motor. i also have a 94 lt1 that has been converted to carb with a gmpp intake. my question is once i have the motor in the car can i use a carb to tbi adapter and get away with using the factory 305 componants? will the lt1 run too lean doing this, if so what can be done to offset this. the reason i sak all of this is im on a tight budget, and if this will not work then im sol. any help would just be awsome. sorry for the spelling guys my spell check to a crap.
Old Jan 12, 2008 | 12:12 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: will this work???
You will need injectors off a 350 (junkyard item?), and a chip. I would recomend a chip that matches your cam or else you will have to swap it to a 350 tbi cam. A good location for custom chips is tbichips.com.
Personally i would convert it to carb, but i guess that is all on preference.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
