AC/Smog removal
Car: 1992 Chevy Camaro Heritage Edition
Engine: 305 TBI
Axle/Gears: Stock
AC/Smog removal
i wanted to take out the ac and smog pump but keep my heater since it can be a nice day adn still be a lil chilly out, i dont need an ac thats why i have windows, but what would i have to do to get rid of all that crap? car is a 92 305 tbi
Re: AC/Smog removal
same thing i plan to do they make what are called "delete pulley" 's for the smog pump and the AC compressor.... only one person makes the smog pump delete pulley and that goes for $65 or around there.... as for the AC delete pulley there are varying ones on Ebay ranging in price from $20 to $60.....
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: AC/Smog removal
There is a write up in the tech articles on removing the SMOG - then all you need is an A/C pulley delete.
Re: AC/Smog removal
Thats actually a pretty neat trick..... and here is the link to the article... thanks for the info camaronewbie......
https://www.thirdgen.org/serpentine
Car: 1992 RS
Engine: Carbed 350
Re: AC/Smog removal
No problem - I did that to mine - you'll have to maybe try a few different belt lengths, as I got the one in the tech article and it wasn't right length. I kept my A/C, but that would save some expense anyways.
Engine: 305 TBI
Axle/Gears: Stock
Re: AC/Smog removal
yea i knwo all about the delete pulleys and stuff, but can i just bypass the pulley all together and use a shorter belt? also that big ugly black box that is on the passenger side firewall that has the heater core in it right? has anybody ever tried to relocate it?
Car: 89 gta ws6
Engine: 350tpi
Axle/Gears: 3.27?
Re: AC/Smog removal
? i have a 89 gta with the L98 with the dual e fans, i was wonderin since i removed all my ac except my compressor that i kept so my fans will turn on, what will i have to do to power my fans and keep it on the t stat switch without my a/c, sorry if im all over the place with this ?
Car: 1992 RS
Engine: Carbed 350
Re: AC/Smog removal
No - the heater core is inside the car, pass side, in the dash - the two radiator hoses that go into the firewall, connect to the heater core. The black box can be removed, many have done it - you'll have to patch in some sheet metal where it is a part of the firewall.
