Where is my Oil Pressure Sensor at?
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
I Have a 1987 Firebird LG4 and i swapped in a 350 Carb'd, and im looking for a aftermarket or a direct replacemnet too?
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Where is my Oil Pressure Sensor at?
oil sending unit is located beside the distributor,iirc it takes a 13/16 wrench to unloosen.you canpick one up at any parts store,same for after market.later jimmy
Car: 1989 Camaro
Engine: 383
it should be right above the oil filter on the side of the block. If its not there look at the very back of the intake just to the driver side of the distributor
It goes behind the distributor.
Just get a stock replacement one at the parts store. About $15.
You'll need the little brass fitting to mount it with, if you don't have that. The factory used a specific purpose one. You can duplicate it by going to the hardware store and getting a 2" long 1/8" pipe nipple and a 1/8" pipe elbow (female threads on both ends).
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah it's about $15.
Mine was above the oil filter... but mine is stock, yours isnt. And some of the stock ones were behind the dizzy. Im not sure which were where. I think later years got it above the filter.
What mine looks like, I suppose yours will probably look similar. So look behind the dizzy and above hte oil filter. Should be somewhere.
That's not a LG4 car. That's a TBI car.
In the LG4, it's behind the distributor.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
All should have the sending unit for the gauge beside/behind the distributor. The one that is above the oil filter, was used for backup power for the fuel pump. If the relay failed, it would send power to the FP, once oil pressure got past a certain point. (I think it was like 2 PSI......)
Car: 1992 Camaro RS
Right; Infernal's is typical of a car with EFI, where the one sensor does both the gauge and the fuel pump functions. The LG4 version doesn't have the fuel pump thing, and goes in that other place.
The 2 holes are actually just at opposite ends of a particular system of passages, so they measure the same thing; just at different places.
There may have been some earlier FI cars with senders in both places, since there's no particular reason that they HAVE TO be integrated; it's just cheaper to manufacture that way. But I can't recall ever having worked on a car with 2. Which is certainly not a claim that there aren't any like that.
But, not a LG4. In the LG4 (and L69), the sending unit for the gauge, is under the distributor.
Car: 1987 Firebird
Well i found it and i cant get the one for the LG4 to fit because it hits the firewall so what should i do? Go aftermarket or what?
Turn the little brass nipple arrangement to point it toward the driver's side head.
That's why you need the elbow..... the 2" long nipple goes directly into the block, the elbow goes on top of that, with the hole for the sender pointed toward the car's left.
Car: 1987 Firebird
The one on the 350 doesnt have a bolt/fitting i can turn.
Then go to the hardware store, and get one.... exactly as described a couple of times above.
There's a reason I typed all that in up there.
There's a reason I typed all that in up there. Thread
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
