Which MagicStick 4 LSA?
Old Jan 27, 2008 | 08:12 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Looking at the TSP MagicStick 4 for my 383 Stroker. What is the difference in the 111LSA and the 112LSA? I know of the overlap, low-end vs. high-end power and crap, but in terms of idle. Which would be more of an aggressive, rough idle and which one would be a smooth "chugging" idle?
Thank you,
- Justin
Old Jan 27, 2008 | 08:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Which MagicStick 4 LSA?
You'd never notice a difference in 111 vs 112 LSA.
Longer LSA tends to give a smoother idle, and the lower would give a choppier lope. But one degree would be almost unnoticeable.
Both will be quite smooth, unless it's got a crazy long duration.
Old Jan 27, 2008 | 08:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
magicstick 4 isnt all that big in a 383 lsx, so go 111
Old Jan 27, 2008 | 09:30 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
ok. thanks. what would be an awesome cam for my 383? Something that has high lift, so when you just touch the gas, it's basically WOT.
And in general, an awesome cam for my 383?
Thanks again,
- Justin
Old Jan 27, 2008 | 10:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Alright, had to look up the cam to see what we're talking about here. I'm not all that well versed in the LS specific cams here. Ok, 239/242? .640/.610" ?
I think that one would work pretty well, but it will be a bit "cammy", so beware of that.
Old Jan 28, 2008 | 09:14 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I know what someone means when they say that their car is "camming", is that what you meant by "cammy"? Huh, new word. Ya learn something new eaveryday.
Thanks,
- Justin
Old Jan 28, 2008 | 09:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i have a buddy running a much larger cam in his 383 all bore lsx and his car runs HARD! its a big grind tho and does give that camming sound thats for sure.
Magicsticks are always a good choice in a 364-383 tho. I think you'll like that cam. The new cams coming out today feature some HIGH lift lobes that will require some GREAT valve springs and alot of companies have made some good springs to handle those cams. Comp cams big block beehive springs are great. AFR 8019's and patriots extreme gold springs work well too
Old Jan 28, 2008 | 10:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, Cammy. It feels like it's got a lot of "cam" to it. With a stickshift you'll feel it. Drive through a parking lot with your "pure torque" TBI engine and it feels fine cruising around at 900RPM through parking stalls right? ok, now with a BIG CAM, but trying to maintain the same slow parking lot speed, it'll buck and surge like crazy. You have to ride the clutch to get through it. Bumper to bumper traffic is a nightmare too. Like riding a bronco really.
But if it's a sunday cruiser or something, and you never intend on fighting traffic with it, no biggie. My 224/230 was a PITA in traffic with my stickshift, my next 240/240 will be flat out annoying - so i'll avoid traffic
Old Jan 28, 2008 | 02:57 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I gotcha sonix. Thanks. Sadly it is my daily driver so sometimes traffic is in the picture. I hate traffic! Oh well, I do see your point, that riding the clutch would get annoying real fast. Thanks for your help.
Jorlain
Oct 8, 2015 01:57 AM
mz92274
Aug 25, 2015 08:47 AM
80s Poncho
Aug 19, 2015 06:45 PM
ViciousZ
Dec 5, 2001 11:32 AM
rallysport
Oct 8, 2001 09:21 AM
