Clicking sound, and rocker question
Old Feb 11, 2008 | 05:59 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Hey, I want to make sure this is a rocker sound. the two links are to the two waves I made of the sound with my DVR so they are not the best quality but you can really hear the sound. this is taken with the valve cover off and the DVR recording over the rockers thats why they sound so loud. the sound is coming from the passenger side only and seems to be on top of the engine and not deep in the engine somewhere.
http://www.angelfire.com/bug2/chriso...nesoundwav.wav with out reving it at all.
http://www.angelfire.com/bug2/chrisola/A0000038.wav with a little reving. but not much
I want to try to adjust my rockers with the engine running. I don't know if I need the disconnect the IAC or adjust them with the enigne running at X amount of RPM and do I adjust them when the engine is hot?
I know I back off the nut till I hear the rocker start to click than tighten it till it goes away and do a 1/2 a turn.
tell me if I'm wrong.
Old Feb 11, 2008 | 09:45 PM
Car: 89 GTA
Engine: L98 350
Re: Clicking sound, and rocker question
I just found these around a valve spring... Remember this is a new engine and I don't remember putting anything plastic in it
Also after letting it run for a while I see water dripping out of the exhaust and the AC is not on, the AC doesn't even work in my car. and when i turn off the car steam comes out of the tail pipe. I don't see any water on the dip stick but I'm thinking about draining the oil out of the engine to see if i can see water floating around.
Please help!! what should I do?
Last edited by Cambridge205; Feb 11, 2008 at 10:10 PM. Reason: found new things to add.
Old Feb 12, 2008 | 02:42 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
exhaust manifold gasket leak makes clicking sounds like rockers and such, very commonly
you sure those pieces arent thin steel ?
is yours a roller cam engine?
might those pieces be sheared from a guide plate ?
upper valve train trouble will not cause water in the oil, etc.,
steam and moisture is going to come out of the exhaust if it is cold out
normal
rockers are actually supposed to be adjuted with the engine stoppped, and warm
zero lash plus one full turn clockwise/tighter if it is hydraulic camshaft
only when the lifter is down all the way on the base/backside of the lobe
this centers the plunger of the lifter in its travel range inside the lifter
good luck
Old Feb 12, 2008 | 03:09 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
As far as water in the exhaust it is just condensate, the plastic looks like a breather broke. when you adjust rockers as the intake is just starts to close adjust the exhaust and when the exhaust Starts to open adjust the intake if it is stock go ¾ turn if you plan on spending some time 5000+rpm go ½ and look at the push rod if it don’t move like the rest the lifter or cam is bad
I hade a bad cam once on my 327 it sucked! Have fun
Old Feb 12, 2008 | 10:03 AM
Car: 89 GTA
Engine: L98 350
the cam is hydraulic roller. the pieces are thin plastic, and I was thinking about the water in oil thing last night and came to the same conclusion, that it cant be a leak. I have been adjusting my rockers like 2kickassbirds says to do but I did 1/2 a turn and they are still noisy last time I did it this sound started happening.
By the way 2kickassbirds this is Chris, Cambridge205 is my new user name it just wouldn't make sense havening 92maroonbird for an 89 white car with a red front. Anyways I just want to get this dang thing running I have been on this engine rebuild way too long.
Old Feb 13, 2008 | 04:36 PM
Engine: 5.8
Is it one rocker or all rockers?
Do all your push rods move the same ?
What kind of rockers are you using?
Did you check if the rocker was on the ball or if the ball was upside down
Are your valves new?
Did you get a valve job if so did you check if the valve was seated properly?
What are the specs on the cam? you could be hearing the valve close
Ha man how is it going you have been on this thing for over 6 months at least you got it running
Did you check out the LTGUN if not go to my car domain
Old Feb 13, 2008 | 08:15 PM
Car: 89 GTA
Engine: L98 350
I put the ratchet on the rocker nuts and put my ear to all of them while the car is running on that side and I heard no difference between any of them.
The heads are new to me the ones that used to be on that car had real bad cracks so I got used ones and had them rebuilt. still L98's and I gave the machinist the cam spec's and he got springs and retainers for the heads to work with the cam.
I know I put the rocker ***** in right. But I still checked and they are all in right.
I don't know how to see if the valves are seated right you would have to tell me how to do that.
The cam is a ZZ4 cam I heard works real nice on l98's specs are, cam lift: .474"/.510" Dur:208/221
Also I had someone cranking the engine to see if the rockers all moved up and down about the same amount and they seemed to do it. But when I was turning the engine over by hand when I was adjusting the rockers some of the rockers looked like they didn't fully open or they would get 1/2 the way open but start to close. I don't know if thats normal for new lifters.
I'm going to adjust the rockers for a 3rd time on that side again sense this sound started to happen after the 2ed time I adjusted them. and see if it helps any.
Nice I knew you wouldn't give up on that car, Nice engine! I wish mine looked as good as that but it never will. but the interior looks nicely parted out are you going to do something about that? Do you plan on making it street legal again I don't think you can, can you?
Hopefully this will be the last problem for my car and I can start to enjoy it again. Than move on to my steering problems Maybe in the far future like a year or so after a paint job I might convert it to HSR till I have to get it emissions tested than its back to TPI
Old Feb 14, 2008 | 12:23 AM
Engine: 5.8
If you have set the rocker that many times move on start looking for exhaust and A.I.R leaks you would be surprised at how they can sound the same. if you have a compression tester you can look at each cylinder and see if there are any different. you can also check your work on the bottom end and if the valves are seated properly a good reading is about 160 or 180+ for a fresh motor. hope you find it
I can make it street legal and I plan on it I jest got it started lasted night but I still have some work before it goes anywhere
Do you plane on racing it you probably got a 14.5 in it?
Old Feb 15, 2008 | 01:24 PM
Car: 89 GTA
Engine: L98 350
I think I found what it was, the check valve on the header was just finger tight so I tightened that and put the hoses on it, started it and the sound was gone. At least it was at that time… I'm an idiot I should have found that oh well hope I didn’t do anything as stupid as that on the engine rebuild.
However I didn’t even think of compression testing it. I think I'll do that after I break it in and see how I did on the rebuild.
Nice work on that car. What do you think it will run? Oh yeah do you still have Iren?
Yeah I plan on racing it! I'm hoping to get my car running high 13s some day and still legal. You might see me going down Old Spanish breaking in my engine. Anyways thanks for your help. Keep in touch.
Mickeyruder
Sep 2, 2015 02:45 PM
B_Dubya
Aug 26, 2015 05:09 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
