Spark plug question
Old Feb 12, 2008 | 03:40 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Spark plug question
I wanna change the plugs in my trans am and I will be putting AC Delco's in it, but my problem is what am I looking for...my set up is, 64-67 327 heads (camel hump) and late 70's 350 block, with a mild build ie .30 over and a mild cam. stock ignition and a 650 holly double pumper. So I can't exactly go down to the parts store and look up what I need, also what kind of gap and heat range should I look for?? any help would be greatly appreciated
Old Feb 12, 2008 | 03:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Spark plug question
Pick a stock application that would have come with those heads, and tell them that's what you've got.
Old Feb 12, 2008 | 03:48 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Thought about that but was worried about the gap and heat range of the plug.
Old Feb 12, 2008 | 03:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The gap you're going to set yourself anyway, and stock heat range is fine for most applications.
Old Feb 12, 2008 | 03:59 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
perfect...whats a good gap then?
Old Feb 12, 2008 | 04:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stock .035" or .045" should be fine.
Old Feb 12, 2008 | 04:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Drive the car around like you stole it for a few blocks, pull over and check the heat line. That'll tell you about the heat range. Chances are it's fine. Open the gap until it misfires under worst case conditions, then close it a bit. Or just use .045" and be done with it
Old Feb 12, 2008 | 04:39 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
sounds easy enough...thanks
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
