gas gauge reads empty, tank wont take fuel
Old Feb 14, 2008 | 01:02 PM
axotarra's Avatar
Car: 95 pontiac firebird
Engine: 3.4L crap box
Transmission: 5 speed
Hey all,
So, my fire chicken is sick again. 5 days ago, I knew my car was empty, the gauge was working everything was fine. I go to the gas station and put 5 gallons in my tank, and then the gauge drops to below empty. I thought maybe the float was messed up or something, so I set my odometer so that I would know how many miles I could drive.
Yesterday, I go to fill up again (the tank is freakin empty mind you) and I can't put more than 4 gallons in until it begins to overflow! My car now reads empty and will only accept 4 gallons or less without overflowing.
Help...
Tarra
Old Feb 14, 2008 | 01:21 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: gas gauge reads empty, tank wont take fuel
is it possible someone vandalized your car and put something in the filler?? Is this on your fourth gen?
Old Feb 14, 2008 | 01:23 PM
axotarra's Avatar
its a 1995 firebird 3.4L v6 and I believe its a 12 gal tank... I dont think anyone messed with it. I am a nerdy girl with little to no frenemies.
Old Feb 14, 2008 | 01:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Uh, 4thgen.org ?
Fill the tank up, then shake the car, see if the float drops or something. Listen for the slosh to give an idea as to how full it REALLY is.
Old Feb 14, 2008 | 03:44 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
my jeep does this the air isn't venting right IMO but i don't know how to fix that, maybe someone will chime in on that. For now pump slower like really slow it will all get in there,probably.
Old Feb 15, 2008 | 06:30 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
This happened to my sisters Grand Am recently. For some reason the tank would overflow and wouldnt accept more than 2 gallons. It wound up being a fuel pump, Why it would only take 2 gallons is beyond me but a mechanic replaced the pump and everything worked fine afterwards.
Old Jun 19, 2022 | 08:36 AM
gerrym's Avatar
Car: '89 GTA Convertible
Axle/Gears: 3:27
Had a similar issue lately with mine. Fill neck was backing up unless I held the pump's nozzle just right and pumped very slow. Short of dropping the tank... .or a maybe a bore scope. ??
Old Jun 19, 2022 | 01:39 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Stevo
Feb 26, 2006 01:10 PM
86birdHT
Sep 3, 2005 03:06 PM
Dante93GTZ
Aug 15, 2003 02:57 PM
SilverSub122
Feb 12, 2003 10:09 PM
86FirebirdV8350
Jan 19, 2003 08:15 AM
