Low Oil Pressure Question.
Old Feb 15, 2008 | 05:19 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
So i did a search and found out that since my oil pressure gauge was reading low that i should change the sending unit. Well today i did that, When i started the car up it read 30psi but quickly jumped down to 15 psi. After driving awhile it goes down to zero and will only jump up to 15psi when i am accelerating. The connector didnt seem dirty or anything when i changed the unit. The previous sensor just stopped working im assuming since my oil pressure gauge always read zero and never moved. There is No Knocking or ticking noises coming from the engine bay just the normal sound of a belt so in my search i never found out what to do after changing the sending unit, What should i do next?
Car is a 91 rs 305 TBI and it has about 90k on it. And since this problem started the car has been driven just about 3000 miles.
Old Feb 15, 2008 | 07:14 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Low Oil Pressure Question.
Well, I would be inclinded to think that a brand new sending unit is working properly. However, the passage to it could be clogged with gunk. I'm not sure if TBI engines have the little brass pipe thing that the sending unit mounts to, but that could also be clogged.
Old Feb 15, 2008 | 07:27 PM
Saber's Avatar
When i took out the old sending unit it was pretty dirty and gunky on the end. How would i get this hole cleaned out? It was a pain in the *** to get the old unit out because of the location. ANy other suggestions on what to do next? Im going to buy a mechanical gauge tomorrow but where would i hook that up to. I just wanna see if maybe the gauge is bad.
Old Feb 15, 2008 | 07:35 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, I would probably do it when you change the oil. I would get a bottle of engine flush, the stuff you add to your oil before changing it. Maybe try running some of the engine flush stuff down the sender hole, along with a pipecleaner or small bottle brush. You cold also try blowing compressed air down it, but I'd keep the pressure low.
Old Jun 25, 2008 | 11:05 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
Im currently in the same boat but i have a zz4 tpi now im losing hp i hope im not ruining my engine maybe my valves need to be adjusted i do hear a little tapping what engine oil shoul i be using maybe thats the problem im sure that5w30 stuff shouldnt be in there and oil does get thinner when its hot
Old Jun 25, 2008 | 12:36 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Remove the electric gauge and put in a temporary mechanical gauge to verify what your actual pressure is. I doubt the oil passage is plugged since you get a reading at start-up that drops after then engine warms up. If the pressure is really that low you need to find out why (bad pump worn engine or ???).
Old Jun 26, 2008 | 12:43 PM
Saber's Avatar
Reaaally old thread lol. Ive got a 350 now, long story short, the 305 was clogged, and do i mean clogged, i ripped the valve covers off and man, was there gunk everywhere, i was getting oil from 1 rocker and that was it, the others were clogged up completly, it spun a bearing shortly after i flushed the engine out and unclogged it. The gauge works fine now and the sendign unit does also(its on the new engine).
In response to the question asked by Newman, i use 10w30 oil in my car, when my gauge was bouncing around i had a clogged oil system, im assuming you mean your loosing oil pressure and not HP? think of it this way, in the crank, when bearings are going they wiggle around creating a bigger hole somewhere in the crank, it takes less pressure to push something through a bigger hole right? That is along the lines of how my mechanic explained it to me when i took it to him after it siezed up on me. I know its probably overly simplified but i get the picture. And i can hear a Clicking when i open my hood, thats the valves and a clicking sound is normal.
Old Jun 26, 2008 | 01:31 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I agree with bjankuski time to find out what is realy going on.
Old Jun 27, 2008 | 08:01 AM
Saber's Avatar
i have a new motor now, lol and no oil pressure problems. Problem solved i guess lol.
Old Jun 27, 2008 | 08:47 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
lol i still need help
Old Jun 27, 2008 | 03:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
newman describe your problem in detail, and as far as I know gm recommends 5w30 for zz4's
Old Jun 27, 2008 | 05:33 PM
evans87's Avatar
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
I have the same problem with my 87 IROC 305 tpi. I have also replaced the oil pressure switch (looks like a bell and is by the firewall) but the problem was not corrected. I do have a little smoke on start up but it goes away after a few seconds. I have no strange noises comming from under hood. It is always serviced and has the proper level of oil. The car has roughly 67k on it and it is driven only a few times in the summer months. I would love to have the problem corrected and welcome any thoughts
Old Jun 30, 2008 | 06:43 AM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
when i start the car up it runs at about 30 psi and when it gets warm it drops to zero i can hear minor lifter tapping and now my engine feels like it has loss hp but im currently getting my transmission rebuilt so ill be ablt to say more later on this week when the trani goes back in
Old Jun 30, 2008 | 10:40 AM
89RsPower!'s Avatar
to both of you I recommend removing the oil pressure switches and installing a known good mechanical gauge and take a reading of your oil pressure and let us know what you find and we'll go from there.
Old Dec 1, 2011 | 05:37 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
How do you remove the valve covers?? is there any special precedure or tricks to do that??? And I can see from the oil filler hole in the valve covers that my heads have alot of gunk in there... same with the PCV valve hole. how do i flush that sh*t out??
Old Dec 1, 2011 | 09:16 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Valve-covers: normally four bolts or nuts. Use a 10mm socket and medium extension.
The best way to clean the gunk out is to remove the heads and get them reconditioned, then reinstall them. If you try to clean or flush them while on the engine you are liable to have bad results that will end up needing a complete engine rebuild.
IF you are set against pulling the heads for cleaning and you still want to do it, then you can pull the oil pan and oil-pump and clean out most of the gunk with the heads still on the engine. This will give you a chance to clean out the pan, the oil pick-up, inspect and re-seal your pump, inspect your bearings, and run a cleaning rod through the passage that goes up to your oil pressure sender.
I think I left out the descriptions on photobucket, but here are some pictures of a similar job, where the owner had a leaking oil pan and wanted the oil pressure to be a little more solid in his work truck.
http://s702.photobucket.com/albums/w...ild/?start=all
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
