What cam to use? Please help!
Old Feb 16, 2008 | 12:44 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
What cam would you guys recommend for a 383 SBC? I"m looking for the largest "streetable" cam that would work with a 383 with 10.5:1 compression with a carb. I'm going to be using an automatic tranny with the appropriate stall converter. Any recommendations would be appreciated. Thanks guys!
Old Feb 16, 2008 | 02:52 PM
Boosted_SS's Avatar
Engine: 383 TPI
Re: What cam to use? Please help!
please guys i need help here what's the max lift and duration and lobe separation??
Old Feb 16, 2008 | 03:00 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
depends on your heads.......... what kind of heads are the guides cut down to run a very large camshaft? Don't over cam it...........
Old Feb 16, 2008 | 06:17 PM
Boosted_SS's Avatar
Engine: 383 TPI
Well I'm just starting this project so everything can be worked around. The short block (except the cam) is the only thing I'm certain about (I know I want a 383). I know I would like to keep the compression ration around 10.5:1. I can make sure the heads are set up to accommodate whatever cam I decide on. I just know I want it big. Any thoughts?
Old Feb 19, 2008 | 06:10 PM
Boosted_SS's Avatar
Engine: 383 TPI
Bump for some help! Please?!
Old Feb 19, 2008 | 06:24 PM
jeffcj's Avatar
My personal choice (for a factory roller block) was http://store.summitracing.com/partde...8&autoview=sku
Comp XR276HR-10.. As flaming-ford pointed out, don't over cam it.
Old Feb 20, 2008 | 02:18 PM
Boosted_SS's Avatar
Engine: 383 TPI
I agree that's why I'm askig you guys who may be more knowledgable about cams then I am. I don't fully understand all the differant ratios and degrees. That's why I'm lookin for advice. Thanks for your reply and I definately look into this cam. If anyone else has any thoughts on this i would love to hear them. Thanks again!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
