TPS screws broke/ stripped
Old Feb 21, 2008 | 06:58 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Hey guys first off shouldn't the TPS sensor once tight not move at all ? Secondly the screws were jammed on there and i actually broke the head off one and now half the bolt is stuck in there!!!
Old Feb 21, 2008 | 09:58 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: TPS screws broke/ stripped
rocdriver,
yes your tps should not move once tightened. Sounds like you might have to take some vice grips or pliers and pull those things off. Once they're both out, your going to have to drill out the threads and use a tap and dye to install the helicoils. I'm not sure on the size your going to need. I'm sure you can drop by a machine shop to have them do it for a few dollars.
Rabi C.
Old Feb 22, 2008 | 07:03 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The screws are an odd ball not US National Fine Thread. Also made of Aluminum.
IRC some posters on TGO have used 10-32 NFT and a steel screw. Do a search on TPS and screw. Good luck.
Old Feb 22, 2008 | 07:10 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
dont pull the screw out. i had the same problem get the other screw out remove the sensor.
grab the screw with a pair of strong vice plyer grips.
turn/twist the screw out so you an still use the threads and screw in a new set of screws.
go to tpiparts.com you buy a new set of screws/bolts there.
Old Feb 22, 2008 | 07:21 PM
tekkitan's Avatar
Car: 87 IROC-Z
sometimes it is just stuck and that isnt an option. i just went through this and had to drill it.
i did get the bolts from tpiparts.com but it doesn't fit because as was mentioned, it isnt a standard size.
i'm just having problems getting the car started now since i put the tb back in, now trying to figure that out
Old Feb 23, 2008 | 12:37 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
since u moved the tps u have to reset it.. .54v on the 2.8's i dunno about the v8's..
Old Feb 23, 2008 | 08:30 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
.54 v min and 4.5 v or greater at wot check with motor off key on.
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
gta892000
Sep 16, 2015 12:37 AM
Amillionoh7
Sep 5, 2015 11:44 PM
