383 clearance question
Old Feb 23, 2008 | 11:46 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
So I have started to assemble my short block and after getting a couple pistons in I noticed a very tight clearance between the bottom of the cylinder and the ARP rod bolts. There is a little raised section on every cylinder where it is pretty close. When I had just the crank in I rotated it and only found one spot that the crank got close to right near the filter stud. I thought I would have to notch the pan rail to clear the counter weights in more than one area but I didn't. Anyway, how much clearance do I need between the rod bolt and the bottom of the cylinders? I have grinded a little bit but I am wary of doing to much right near the machined part of the bores. I have about .040 of clearance right now on the bolts. Is this enough?
Also, I don't have my cam yet but the rods came from eagle clearanced for "up to .600 of lift". Do you usually have to clearance the rods any more or are they clearanced as advertised? I am planning on running a xe274 by the way.
The rods I have are pn SIR5700BBLW
and it is a eagle esp 3.750 crank.
All parts are new and were purchased as a kit.
Old Feb 24, 2008 | 12:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 clearance question
You could take more off without any trouble, but .040" should be ok.
Your rods might clear the cam, but the only way to be sure is to check.
Old Feb 24, 2008 | 08:27 AM
A tie-wrap makes a convenient go/no-go gauge.
Old Feb 24, 2008 | 02:15 PM
sweetaq's Avatar
Car: 1982 Z28
Cool thanks guys. I think I will pull it apart and take a little more off. No sense in getting lazy now. I think I will shoot for .050 to .060.
Mickeyruder
Sep 2, 2015 02:45 PM
lt1z350
Aug 28, 2015 05:57 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
